Old 04-29-2016   #21
Tripler
Tripler's Avatar
Default Re: OUR NEW BABY BOUNCING Z
A few more pics before purchase and the day we picked it up before I installed the plates .
Tripler is offline   Reply With Quote
Old 05-20-2016   #22
Tripler
Tripler's Avatar
I installed our Mark Haibeck chip 2 days ago that we won at the NCM auction and wow !!! What a difference . It starts much smoother now and idles smoother also . Easy peasy to install after a short chat with Mark . All 16 injectors on startup . Loved seeing the full key light on without touching it . Thanks again Mark for building this awesome chip .
Old 05-20-2016   #23
Beeeeautiful car!! Des need not be concerned about getting teary-eyed behind the wheel. That happens, along with a good case of permagrin!
Gotta Q about the chip. Did you have to tie the secondary Port Throttles (SPT) open, or does the chip simply switch to FULL ENGINE POWER and open them on start-up?
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-20-2016   #24
Riviera
Riviera's Avatar
Hi Paul: It opens them on start up. The "Full" light comes on immediately.
Riviera is offline   Reply With Quote
Old 05-20-2016   #25
Paul, 91 and later are different from our 90 cars.. in 1990 you set the key and forget it ( stock function). if I have it is Full power it is always there.
in 91- later, in stock form, every time you start the car you need to turn the key (spring loaded) to engage full power mode.
So in Riviera's car, the chip defaults the car to full power mode at start (stock defaulted to valet) it does not 'open' the secondaries at start , but rather allows for full function of them without having to turn the power key at every start up
