Old 04-24-2016   #1
MuRCieLaGo
Default Left rear clunk
Hi,
When I bought the car, there was a clunk on the rear left suspension. I've been to 3 different garages and none of them could tell me where's the problem (including official inspection).
Can't see anything wrong from underneath.
You guys got any idea?
Old 04-24-2016   #2
Default Re: Left rear clunk
Can you describe the noise with more detail?
Old 04-25-2016   #3
BigIke
I just had an inner half shaft u-joint fail, was doing the same thing.
When your driving, will it pull to one side when you load it, then pull to the other when you unload? I think torque steer is a good indicator of a failing u-joint.
Roll down driver and passenger windows, jack up the drivers side. Block the wheels, off the parking brake, put the car in neutral. Now grab the driver (left) half shaft and rotate it back and forth.
Got sloop? Replace the u-joints with.
2 x http://www.amazon.com/Spicer-5-3615X...ilpage_o02_s02
2 x http://www.amazon.com/Spicer-3-70-48...ilpage_o02_s01
Safety First
BigIke is offline   Reply With Quote
Old 04-25-2016   #4
Jagdpanzer
Jagdpanzer's Avatar
Another good u-joint source
http://www.dennysdriveshaft.com/p422..._rebuild_.html
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 04-26-2016   #5
MuRCieLaGo
Will check that out, thanks guys!
Old 04-26-2016   #6
MuRCieLaGo
Everything seems to be tight there, I recorded a quick video of the clunk.
https://www.youtube.com/watch?v=QYQbYYCz-Ag
Old 04-27-2016   #7
5ABI VT
my guess is the sway bar end links. Have they been changed before or do they look in good condition? the rubber deteriorates over time and the metal sleeve will clink/clunk on the sway bar going over bumps.
Old 04-27-2016   #8
I agree. I had a clunk in the rear of the 95 when I backed out of my driveway. Only 21,000 miles on the car. Marc looked it over and didn't see anything obvious but said the sway bar bushings looked dry. Replaced them and the clunk was gone. --Bob
Old 04-27-2016   #9
MuRCieLaGo
Would make a bit of sense. I will remove the sway bar link, and see if the clunk goes away (I know a car can drive fine without a sway bar). I'll change it if I don't hear the clunks anymore.
Old 04-27-2016   #10
RussMcB
I changed my links recently and my original, old bushings were in very sad shape.
FYI, (in case this saves you 10 min) - You can probably just remove one of the end link bolts, then tie-wrap the end link snugly temporarily as a test (rather than remove the entire end links).
