#11 |
![]() Join Date: Apr 2007
Together with new cams target is around 50 hp.
Dom, are you referring to the Cosworth lifters I recall Sam mentioning a while back. Has anyone seen a spec sheet on these?
#12 |
![]() Join Date: Jul 2005
Phil,
Did you install bigger valve seats?
Sam DR.Z/LT5-Performance 1990 #1822 with 383 cui |
#13 |
Yes, 42.85mm OD
#14 |
Not sure if Cosworth or Porsche. I know Sam can fill you in on them. A set of them is circling O'hare right now as I understand it. Significantly lighter I was told.
#15 |
I did send out before to the company a stock LT5 lifter for measuring and checking all components and sizes and if the light lifters match. Also I told them about the weight of all moving parts and the spring pressures. The leight lifters can handle with.
Sam DR.Z/LT5-Performance 1990 #1822 with 383 cui Last edited by SAM/CH ZR-1; 02-15-2016 at 06:51 AM. |
