02-09-2016 | #21 |
Re: Single Mass Flywheels
Thanks for your post Jitse!
02-09-2016 | #22 | |
Flywheel: http://www.jerrysgaskets.com/flywhee...let-90-95-0b1/ Clutch Disc:http://www.jerrysgaskets.com/clutch-...hub-89-95-000/ Pressure Plate: Stock/OEM pull-release
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 02-11-2016 at 02:14 PM. |
02-09-2016 | #23 | |
ed ramos #3028
EDRAM454 1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD. |
02-09-2016 | #24 |
I know.. just confirming the set-up with the 22#
