Closed Thread
Old 01-18-2016   #11
Default Re: LED headlight upgrade
Do you have an eBay link? Curious as to what ones you ended up with.
-=Jeff=- is offline
Old 01-18-2016   #12
http://www.ebay.com/sch/i.html?_from...d+5x7&_sacat=0
secondchance is offline
Old 01-18-2016   #13
ZR1North
Mine are Truck-lite brand LEDs and not GE. Plugging wasn't that difficult. Remember-driving light ground wire has to be modified per Hib's article.
I noted the difference which is why I asked. Will keep this in mind - thanks for the update.
ZR1North is offline
Old 01-18-2016   #14
HAWAIIZR-1's Avatar
Awesome!!! Thanks for sharing Yun....I'm all over it.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
HAWAIIZR-1 is offline
Old 01-19-2016   #15
C4Ray
Great topic!
C4Ray is offline
Old 01-19-2016   #16
BigIke
WOW! The SlilverStars are good lights... Those Nighthawks are amazing! Thank you, I've been looking at those since i go my Juan...
1991 White ZRJuan #1616
Mileage: 56K Sept-14 -- 113k May-18!!!
God Damn I Love This Car!
BigIke is offline
Old 01-19-2016   #17
USAFPILOT
USAFPILOT's Avatar
any chance of a how to thread for this conversion...it seems a much better option than HID's
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI.
USAFPILOT is offline
Old 01-19-2016   #18
Really not much to it:
* Rotate headlights half way. I normally turn the headlight switch to full on followed by switch to off position and back to parking light only position when in desired position. Or, use manual knob to rotate to half way position.
* Now, two screws on the sides of the light bezel is accessible and remove able.
* Remove two T-15 tore head screws on lower edge of the housing. Get ready to catch the housing as these bolts are removed.
* With the housing removed four screws for the stainless steel band trim holding the headlight in headlight bucket can be removed.
* Pull the headlight forward just enough to expose electrical connector to the headlight and disconnect.
* remove headlight.
Installation of new LED headlight is the reverse of above steps.
Refer to Hib's picture and re-wire driving light ground wire (green wire) to counter inoperable driving lights caused by factory wiring where driving light ground is through the high beam ground:
http://www.corvetteactioncenter.com/...age=799_11.jpg
Old 01-21-2016   #19
ghlkal
ghlkal's Avatar
What the ... ?! You guys drive your Zs at NIGHT?! Isn't that like driving in the rain
Seriously, this looks like a great upgrade.
I know we won't be driving in the snow, but since LEDs don't produce much heat, the lens could get coated with ice. We've had this discussion on a snowplow forum and the big downside is having to clear them off as you're plowing.
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
ghlkal is offline
Old 01-21-2016   #20
Maybe Robert should look at this as a "group buy" candidate.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
XfireZ51 is offline
Closed Thread
