12-24-2015 | #1 |
New LT-5 Wiring Harness...Restomod
Got this with an engine I bought. Was supposed to be for a 32 Coupe getting an LT-5
Seems to have everything and is labeled; including DIS 14 pin. $400 OBO, nice piece
12-24-2015 | #2 |
Re: New LT-5 Wiring Harness...Restomod
So...this is a complete LT5/ZR-1 wire harness with all the connectors in good shape?
I have an interest |
12-24-2015 | #3 |
never used brand new
12-24-2015 | #4 |
What year might that be?
I am not familiar with the differences if any between 90-91 and 92-95. |
12-24-2015 | #5 |
The engine is a 90, again this was going in a restomod....we can talk on the phone and walk through it if you want. the secondary MAP looks like a 93-95 to me
12-24-2015 | #6 |
The Chip in the ECM said 90 ZR-1
12-24-2015 | #7 | |
So you have an ECM and 90 Chip also And it is brand new wire harness but came with a 90 engine with ECM and chip but you think there is some modifications which look like 95? I will check when daylight A couple close up pictures of the ECM connectors and other connectors would be of interest.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-24-2015 at 02:17 AM. |
12-24-2015 | #8 |
If it's a modified GM/OE harness it's very likely the wrap with the GM# could maybe still be present.
'90 most likely ..0375, ..0376 '91 ..0870 '92 ..7829 '93 - '95 ..1078 The tag would normally be found wrapped very close to the C100 connector. |
12-24-2015 | #9 |
I think this is done by painless or someone like that
12-24-2015 | #10 | |
Wiring Harness Identification
Lee....what number if any do you find? I did find a 0376 on a 1990 Harness I am using.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-24-2015 at 06:12 PM. |
