Old 12-06-2015   #1
Billy Mild
Default Intake sensor relocation
http://www.zr1specialist.com/HAT%20W...r%20sensor.htm
Has anyone done this mod themselves? Did it make a difference?
Old 12-06-2015   #2
Default Re: Intake sensor relocation
it very easy, not sure you will notice seat of the pants improvement, but every little bit helps. I put mine down in the well by the secondary vac pump reading outside air
Old 12-06-2015   #3
Moved mine to the plastic filter housing
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 12-06-2015   #4
I have mine in the same location as We Gone. However, the purpose of this mod is to avoid the MAT being heat soaked and providing a false signal to the ECM.
Locating the MAT further upstream of the intake air charge provides a more consistent Intake Air Temperature signal BUT you cannot take advantage of it unless the calibration is modified to reflect that change. The stock calibration is expecting a nominal temperature of ~ 80C. At that those temps, the ECM uses intake air and coolant temps in equal parts to modify fueling. Relocation of the sensor effectively eliminates sensor readings of anything above 40C or 130F. At this temp, the ECM is using the Intake Temp over the coolant temp to regulate or modify the fueling.
The result is that the motor will run richer than it should be. The purpose of the MAT/IAT is to help ECM regulate fueling so that it is consistent over a wide spectrum of intake air/coolant conditions. IMO, not worth doing unless the calibration is modified to accommodate the relocation.
Old 12-07-2015   #5
I did this early on with the '93 (back in '95) and on the '95 Marc located it down in the grille opening. Can't say that one item makes a noticeable difference but it is logical that a more consistent and accurate ambient temp reading will feed better data to the engine computer. One of the little things that add up to a better running Z. --Bob
Old 12-07-2015   #6
And, what if the TB coolant is bypassed. The temp of the air horn is very close to ambient air temperature; within a few seconds of run time. I wonder about the impact (if any) that has? Hummmm....
Old 12-07-2015   #7
this might be on a C5 test vehicle
http://teamzr1.com/dyno1.html
Old 12-07-2015   #8
Billy Mild
Is this saying a possible 10 HP gain from moving it?
Old 12-07-2015   #9
Not sure if its a gain, or just not losing it to heat soak....so its not pulling timing. It takes 30 minutes to do and less than $20....can't hurt
Old 12-07-2015   #10
Billy Mild
Does anyone have the stock location of the sensor? I may just do this over the winter along with a few other mods.
