Old 12-05-2015   #1
Default Idle to high around 2000rpms
So I need some advice from the experts. I have a good friend here in Ga. who has a 91 P&P headers exhaust and tune If i had to guess 500 flywheel HP.
He can not get the idle down below 2000, This just started after the car sat for an extended time. I went over and helped check out the normal things such as vacuum or vacuum leaks none found. I hooked up my scanner and what I did find was a code 62, and the 02's never cross counted the stayed around 750-800 both right and left just a flat line??
He does run a % of race gas in it could that have burned up the 02's?
Will the 02's create this high idle issue?
Thanks Guys any help will be great.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 12-05-2015   #2
RussMcB
Default Re: Idle to high around 2000rpms
Steve, are you sure there isn't a vacuum leak under he plenum?
When my (stock) ZR-1 had a 2,000 rpm idle, Marc H said (almost immediately) it was a vacuum leak, and he was right.
I'm not sure if fouled O2 sensors might cause high idle.
Good luck.
Old 12-06-2015   #3
Funracer
I agree vacume leak. Last time I left a vacume hose off under the plenum
it idled at 2000. Pulled plenum again, reattached loose tube, prob solved.
Funracer is offline   Reply With Quote
Old 12-06-2015   #4
IIRC a Code 62 is a left side O2 sensor running lean. Race gas could poison the O2. 750-800mv means rich. Could be ECM is trying to compensate. What are your IAC counts. I'll guess they're above 35.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 12-06-2015   #5
Thanks guys, The secondary vac system was in good shape and only cycled every 30+ sec. and than only a few burps. We did not want to pull the plenum just yet, may be my fault I got focused on the 02 readings. I to was thinking the ECM was trying to compensate, I don't remember the IAC counts and forgot to push the capture button.
We got to talking about car and stuff I had not seen Mark in many years so we had a lot to catch up on. I'll make a trip back when I get more information may be a few weeks as its about a 100 drive one way. Was a great drive in the 93 for me!!! but the cam cover washer I replaced was still seeping just a bit.
I hope he does not mind but this is his beast...One great looking ZR-1
Steve
1990 Red/Red #1473
Old 12-06-2015   #6
RussMcB
I agree. Very nice.
Old 12-07-2015   #7
Any other ideas or comments.
Steve
1990 Red/Red #1473
Old 12-07-2015   #8
You have verified the MAP hose? Its sounds like an under hose plenium leak. The MAP would/should show an open fault as well
Old 12-07-2015   #9
Option other than bad O2: Verify whether the 2000 rpm idle is vacuum leak or throttle related. Put a heavy book or piece of plywood over the air horn while running. Engine dies, it's throttle or IAC related, keeps running, it's vacuum.
Old 12-07-2015   #10
Yep thats right Jerry anything that can block the intake I used a piece of cardboard it does the trick as well
