Old 11-29-2015   #21
Default Re: Clutch recommendations
Originally Posted by efnfast View Post
I sent it to the machine shop and they resurfaced. I probably should have just bought a new face for it.
Yeah I thought that was the whole point. Just replace the friction surface.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-19-2016   #22
efnfast
Thought I should update this thread. Just back back from MR4 and BG. Clutch performed flawlessly, I've changed nothing.????????
Old 05-20-2016   #23
edram454
edram454's Avatar
I have the Fidanza and stock PP and the Camaro sprung hub disc (Centerforce fm Summit #381039). Love it!
Also, (it's been a while now) I installed longer (custom) bolts that were part of a kit that included the drill bit and tap, as I recall. (Maybe Dom remembers or has the info on the bolts - I (alas) have lost track of the particulars...)
If and when I need a new clutch, I'm going with the RAM dual-disc setup and be done with clutches thereafter! (I'm assuming their clutch will work with the Fidanza, but maybe not.)
Me too. works like a biatch!!
ed ramos #3028
EDRAM454
1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD.
Old 05-20-2016   #24
efnfast
Ed, don't assume that their clutch will work with a Fidanza, it doesn't. Which, I would assume means it won't work with stock.
Old 05-20-2016   #25
BigIke
glad to hear it started working for you brother!
1991 White ZRJuan #1616
Mileage: 56K Sept-14 -- 113k May-18!!!
God Damn I Love This Car!
BigIke is offline   Reply With Quote
Old 05-21-2016   #26
dredgeguy
dredgeguy's Avatar
All the down shifts on MR4 and on the track do wonders to cure clutch issues. Maybe coasting down the mountain when you were on fumes worked as well. Sitting in Lagos now thinking of all the fun from last week.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 05-21-2016   #27
And, then there's....
Originally Posted by HIZNHRZ View Post
I'm running a RAM clutch package with the factory dual mass fly wheel and I'm very pleased. Work was performed by Marc Haibeck.
Maybe someone can "Splain it to me Lucy!"
IF the OE pressure plate will work on the Fidanza (my case), and the RAM PP is working on an OE dual-mass FW (HIZNHRZ example), both proven applications, I'm at a loss to understand why a the RAM wouldn't work with the Fidanza when it does with the stock PP. And....NOW you say it does work - the Ram/Fidanza combo... Is that right?
I do recall there was a break-in procedure for a new disc. The surface of the PP is/was beveled in toward the center. Therefore, the new disc needed some time to conform to the shape(s) of the PP. Otherwise, there was a risk of slippage and even burning the disc and PP along the outer contacting edges of the PP/disc.
This "break-in stuff" may be grabbing at straws, not knowing the facts in your application, i.e., the RAM PP in particular. But, I thought I'd mention it because I DID do a break-in procedure immediately after installing my OE PP/Fidanza FW. (NO issues at all in over 15,000 miles and a few trips to the drag strip...FWIW!)
Generally speaking... We have so very few manufactures that are willing to work with us to re-manufacture or develop custom parts to keep our Zs on the road. So, I'd hate to see one or their agent(s) get unjustly maligned resulting from a procedural mis-que...Just sayin. Thanks for the update, Steve!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-21-2016   #28
efnfast
Unfortunatly I was not part of the installation procedure. The whole clutch thing started because I bought a Fidanza. Figured I'd upgrade to the RAM while in there. One thing I did discover: Speaking to Marc H, he said he always has to grind out the bushings RAM sends. I don't mean to put words in Marc's mouth, maybe not on every application. Paul, I also installed (had installed) the hydraulic throw out, maybe that's where the issue lies.
I couldn't find any instructions on breaking the clutch in, maybe it needs to slip to wear in. As soon as it started to slip, I'd back right out of it.
I didn't mean to disparige anyone, or throw anyone under the bus. I tried to stick only to the facts as I knew them. It had been a bit since it was installed before I posted, so I may have forgotten some of the story as it was relayed to me. - Steve
Old 05-21-2016   #29
SCCAForums
For those with stock ZR1's, are there any oem equivalent clutch and pressure plates that still will work with OEM Dual Mass Flywheel?
Best Regards,
Dave
SCCAForums is offline   Reply With Quote
Old 05-22-2016   #30
Racinfan83
There are a few around. But most of the people who have them are hanging on to them. Best bet would be to contact Marc Haibeck at ZR-1 Specialist and ask him if he knows where any are at...
