Old 11-01-2015   #1
tf95ZR1
tf95ZR1's Avatar
Default Compression Test
I borrowed a Snap-on Compression Test kit from a buddy. It has
(4) different 8" long hard rubber hoses with one end threaded for the spark plug hole
and the other end an air compression fitting for the gauge.
The threaded end has a thick rubber washer, but with our deep-
sunk spark plug seats there is no way to get in there and tighten
the hose down. Is finger tight OK?
I also saw you can get rigid extentions. Is this what you guys use?
Thanks,
Ted
Old 11-01-2015   #2
tf95ZR1
tf95ZR1's Avatar
Default Re: Compression Test
Thanks Jeff & Dyno.
We need to get some sleep.
Old 11-01-2015   #3
Speak for yourselves
Finger tight is fine and flexible rubber extensions are fine
See Item #4 LT5 Final Inspection including Brake Tricks
Compression tests
