10-27-2015 | #21 |
Re: Stalling issues - Code 31 (Camshaft Position Sensor)
That FSM should have what you need, Their is one more supplement for the LT5
Here are the book #s ST-364-91 Service Manual covers L98 & LT5. ST-364-91 EDM Electrical Diag, supplement. ST-364-91SB Service updates. ST364-1990/93-LT5-Supp. When you get them read-read-read I brought up the chip as GM had a few revisions to address idle issues they should be in the link on Mark's site http://www.zr1specialist.com/HAT%20W...librations.pdf A very good tool to have, makes reading codes so much better than the paper clip!!!
Steve 1990 Steel Blue/Black #2355 1990 Red/Red #1473 1991 Quasar /Black #118 Sold 1991 Turquoise/Black #766 Parted Out 1993 Yellow/White #179 Sold 1990 Black/Gray #1361 Headers/4:10s Sold Last edited by We Gone; 10-27-2015 at 03:48 PM. |
10-27-2015 | #22 |
All the 4 books are about to be bought now. Will probably be on their way home tomorrow.
Dynomite's Code reader will also be bought if he is OK to ship in Canada. I hope it will help me in the future. I know you must think I'm in a rush. Reality is: I won't be able to drive the car in less than two weeks because of winter time. I don't want to have the car sit in the garage for the next two weeks... I can easily fix it as a winter project (but I got all my time now to fix it, I work on a ship and I'm off at the moment). Do you think the chip *could* fix my problem? |
10-27-2015 | #23 |
And I hope the manual will help me diagnosing the IAC because I can't find anything on that subject on the forum...
10-27-2015 | #24 |
No, When I first got my 91 back in 02 it had an outdated chip I changed it than later went to one of Mark's tunes, also one of the first things I did when I got my 93, So just worth checking.
I'm not in any way suggesting your rushing, Just know when I get frustrated I stop and reread about what I'm checking many times just to be sure I don't miss something.
10-27-2015 | #25 |
Murcielago,
I suggest one quick check. Check the MAP sensor to back of the plenum hose. If it has blown off or if you see a soft rubber hose replace it with proper MAP sensor hose - hard plastic with rubber fittings at the end only. Regular vacuum hose will soften with time and collapse under high vacuum preventing the MAP sensor from getting accurate info. It's an easy check with a flashlight. Also check the code using paper clip method to be sure. |
10-27-2015 | #26 | ||
P/S 30353. 12/22/2014 is pretty recent... I'm not yet frustrated, I just read a lot at the moment. Quote:
10-27-2015 | #27 |
I also noticed an oil leak there. What is that hose?
10-27-2015 | #28 | |
Changing Fuel Injectors TIPS Bad injector/burnt valves TIPS Secondary Injector Drivers TIPS Checking Injector Resistance with Plenum in Place TIPS RC Injectors Fuel injector testing electrical Fuel injector testing pressurized Bad injectors |
10-27-2015 | #29 | |
Just need to understand the diagram now. FSM is on its way. |
10-27-2015 | #30 |
Update:
Just started the car cooled down now. It's cold here (38F) heater was off. As soon as I pushed the arrow to increase heating (from 73 to 74), the car died. Started back, went up to 2,000 RPM and died again. Pushed the OFF button and no dying issue. Now I really don't know what it means. |
