09-05-2007 | #21 |
Re: A Story from long ago...water pumps...
Hi Jim. I am probably in danger of hijacking this thread but........... If I understand the question correctly 'how much should a waterpump cost'?
I have been offering NOS water pumps for years at under $300. I believe that the inventory is much larger than it would appear. I do however believe it prudent to keep an extra one if you have it because many auction sellers are charging mucho bucks and I suspect it can only get more expensive as the "none available" perception increases over time. A little homework can save a person substantial $$ on at least this item. |
11-16-2007 | #22 |
Recently joined the registry - found your post and was wondering if you still have any water pumps available. I think mine has gone south for the winter! A couple of weeks ago I had anti-freeze "squirting" up from the front of the engine - squirting to the pass side. Now have anti-freeze coming from upper front engine area (somewher) dripping back along oil pan when the engine is running. Have yet to get it up on a rack or jack stands to check for sure.
11-16-2007 | #23 |
Hi Mike. After you have completed your diag and if you need a waterpump I still have a few NEW, NOS waterpumps
available, @ $275.00 shipped. (in Cont. U.S.). Just email me if I can help. john.sullivan@protective.com |
11-19-2007 | #24 |
Just two cents from a fellow brother of the beast.
Mike if you do need a w/p do not hesitate to deal with LGNDLT5! I bought one awhile back and the deal was smooooth as silk! Merchandise is the real deal! to LGNDLT5! I bought mine for "stock". Tom
11-19-2007 | #25 |
Tom, thanks for the info - am about to put the ZR up on jackstands right now to verify that the pump and not a hose is bad.
11-19-2007 | #26 |
John, thanks for info - am about to put ZR up on jackstands to verify where the leak is - I will get back to you soonest
