08-15-2015 | #61 |
Re: Point/Counterpoint: DOHC v OHV
Im surprised nobody caught it sooner. BB?
ed ramos #3028
EDRAM454 1990 #3028..siamese ported plen/hous/SGC/fidanza/DRM LTHeaders/DRM roll cage/camber rod/drilled slot rotors hawk track pads/grand sport calipers/full corsa exhaust/Hurst/NO cats/custom SGC chip/cbeamplate/315's on all 4/intake water plugged/smog removed..RC injectors/LED lights..SHOULD NOT HAVE PUT ALL THE MONEY IN IT.. SOLD. |
08-15-2015 | #62 |
thought that was standard short hand.
08-15-2015 | #63 |
Although it's a 427, that doesn't make it a big block. It's still an LSx block just a bigger bore. I may be oversimplifying it.
08-15-2015 | #64 |
fair point, well made and nicely presented. I'd forgotten that the ls7 was a sbc
08-16-2015 | #65 |
My mistake. I thought it was a BB.
08-16-2015 | #66 |
The LSx all have the same block dimension, but I took at as any v8 over 400 cubic inches to be a "big block" as the historical packaging generally had its threshold at about that size.
08-16-2015 | #67 |
I had a 70 1/2 TA that had a 400 small block (Ram Air III). If I'm not mistaken the "small block/big block" designation was only applied to Chevy engines, tho. But the Pontiac 400 was always referred to as a small block.
08-16-2015 | #68 |
396 was a big block back in the day, so displacement was not the determination for the designation. BB cylinder heads would not work on a small block and vice versa.
08-16-2015 | #69 |
I thought it had to do with the bore spacing?
08-16-2015 | #70 |
Well you could say bore spacing has something to do with it. Here's a very illustrative video of the difference. The name "big block" becomes pretty obvious.
http://youtu.be/LPZuEWli4gQ
