Old 08-06-2015   #21
KILLSHOTS
Default Re: Whats Next?
Let's see if it does that sans SC and using a 5.7L displacement while idling at 850rpm. That's really my point.
I feel like we're really hijacking Lee's thread here, but...
An LT1, without forced induction and with the stock cam but with head porting, aftermarket intake manifold and TB, catless headers and x-pipe, as well as computer and fueling mods, can definitely achieve similar numbers. In fact, with a meager investment of about $1000 in a Borla X-pipe, a flex-fuel kit and a tune and a tank of E85, an LT1 can easily exceed 500 crank HP. I was just reading last night about a similarly-modded Stingray on drag slicks dropping into the 10s.
Old 08-06-2015   #22
Billy Mild
FI is the only way to go for big power.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 08-06-2015   #23
I am interested in the ITB setup....doing some research. I called Kinsler awhile back and they said $3-10K for an intake.
Old 08-07-2015   #24
Well for me its a 2009 and up ZR1. Thats whats next or a CTSV for me Lee
Old 08-07-2015   #25
USAFPILOT
USAFPILOT's Avatar
It would be something to see an LS9 blower on an LT5.
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI.
Old 08-07-2015   #26
Originally Posted by Bearly Flying View Post
Great experiment Lee.
Altho peak power was down, were there any gains down lower in the curve?
The dyno started at 3400....but power was down across the board
Old 08-08-2015   #27
Yeah-but!! Ya forgot to mention purchasing the LT1 initially (might add a few $$), ADD to that the computer and wire harness, interfacing it (?) with the CCM, etc., swapping it with the LT5, AND then whatever mods to then get the LT1 to 500+ NA...stuff like that.
Review & Re-focusing:
  1. The "state-of-the-art" for a street-driven, stock-bottom/cammed LT5 is (already) 510+ chp
  2. Cammed but still streetable the 350 cid LT5 is about 557 chp (Pete's example)
  3. The single runner, cammed Phase-II 350 cid LT5 made approx. 550 chp
  4. 540 chp is readily available w/ stock cammed LT5s sporting 368 cid (10 cid less than that LT1 example)
An improvement over these (above) established benchmarks would have to be approx 10%+ in order to clearly put the results above questions arising from test-related variances. In that regard, (as I see it) Lee's experiment started out in the hole, relative to currently established benchmarks (above).
ITB, split plenum, or some other established NA approach may yield that 10% NA improvement (from air induction only) are possibilities with results yet to be seen(?).
The elephant(s) in the room is forced induction - above displacement. Not dismissing displacement or the chance for eking out a few more ponies from NA, but what interests me is exploring a "cost efficient" blueprint to a SC for the LT5.
And, (with all due respect) far as time-slip comparisons go; comparing different cars, different weights and weight distribution, different displacement, different gearing, etc, in attempt to make a comparison between the new LT1 and LT5 all combine to (as statisticians say) "increase the % of ambiguity to the point of irrelevance" (at least as far as this tread goes).
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 08-08-2015   #28
KILLSHOTS
I wasn't attempting any comparisons whatsoever. Even though I've moved on from my Z, I have a soft spot for the LT5 and always will. Comparing a C4 ZR-1 to a new Stingray is the epitome of "apples and oranges".
If you truly want to refocus, then please try re-reading my statements vis-a-vis post #17...
Dom suggested that the LS/LT guys try making big power with stock heads. I pointed out that the Z06 has stock heads. Only THEN was the Z06’s supercharger brought up. So I responded with examples of easy big power without superchargers. I did not – and my intent was certainly not to – compare the LT5 to LT1/LT4 engines. Further, this thread is about Lee’s cool experiment with an open plenum, not about what current gen LT engines can do with 25-year newer tech and cheaper parts.
Old 08-08-2015   #29
No offense intended; really not taking issue at all. As it happens, whenever the LT5 modifications/performance topic comes up, virtues of the current GM motors comes up as predictably as sunrise w/o acknowledging the "apples to oranges" aspect of the comparisons.
By "refocus", I meant to examine the scenario at hand; that is, the 5.7L LT5 platform modifications/results, specifically to the exclusion of other platforms to limit contaminating the discussion.
As far as Dominic's post goes, I don't know for sure, but "reading between the lines" I suspect Dom may have been endeavoring to expand the LSx performance characteristics comparisons to include the near idle or low speed drivability comparisons accompanying the performance spectrum ; i.e., smooth or near smooth idle (would be my guess). For example:
Likely as not, when id comes to performance mods, driveability (especially at idle or stop and go traffic) gets the short shrift; some even go so far as to say, "who cares if it idles rough as long as (speed/power) is achieved?"
Well, perhaps that's all that matters to some. But, to others, myself included, a rough-idling, over-heating in traffic, often stalling beast with high stall rpm converters, or no off-idle torque...is no fun to drive: been there, done that!
So, another way of evaluating performance is to include drivability (stock or at least nearly stock smooth idle and manners in traffic with the AC turned on and meeting emissions criteria ; "Having your cake and eating it too!" in other words). When you do that, a lot of motors (big cammed especially) go out the window. But, this is where the DOHC shines! (I think is at the core).
90 #1202
Sans secondaries
Old 08-08-2015   #30
having finally driven a c6z06 I have to say that the car is worlds better then the zr-1, as it should be for being so much newer, but the power delivery FELT almost identical.
