Old 08-06-2015   #1
Draguy699
Default Build Sheet
Where would I find the build sheet on a 95?
Draguy699 is offline   Reply With Quote
Old 08-06-2015   #2
WVZR-1
Default Re: Build Sheet
The same usual places, top of or on rear face of fuel tank and stuffed in the front suspension member.
NCM?
Old 08-06-2015   #3
Draguy699
Fund tank sticker stuck under strap, can't find one in front. Is it near front spring?
Old 08-06-2015   #4
With the vin # the NCM used to supply you with the build sheet and window sticker. Call them or look up the web site and ask if they sell the build sheet and window sticker.
Here :
https://webservices.corvettemuseum.o...buildsheet.asp
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 08-06-2015   #5
WVZR-1
You should only require ONE! The one in the suspension member requires a substantial effort to remove or even see. Maybe one of those bore-scope lamps/camera might put is 'in sight'. Tucked in the member where the control-arm mounts as a rule.
