Old 07-19-2015   #1
Roadster
Roadster's Avatar
Default Have your Climate Control Buttons ever not respond to your commands???
Took the Z to work on Thursday and noticed on the way home that I was not getting any response from the Climate control Buttons. Thankfully the AC was on, at least it was a cool ride home... Could not even shut the system off.
So I got home and did a search and this is what I found on you tube....
Climate Control Repair- C4 Corvette (can't get the link to copy, but here is the title.) So he has the same problem on a 93 and proceeds to show how it may be possible to get the panel to respond once again, by taking it apart and cleaning the contacts, etc.
Let me tell you, his process worked great, my panel responds instantly with any command, what a pleasure to know the system is once again 100%.
Here are some pics of what I did, I also found that behind the center top vent that the foam was hanging, therefore impeding my air flow, used super glue to reattach and you should feel the flow now......
Forgot to take an actual pic of the Climate Control inner board removed where you clean the contacts, but you will see that in the video I referenced too.
Also replace the Bose while everything was apart, with the unit I bought about a month ago. Plays excellent and now the CD system works perfect. Will get my original Bose repaired some day.
The antenna making a buzzing noise as it reaches the top of its travel, and does not go down completely when turning the radio off. (up about 3").
But that is for another day.
Pic #1.....the Climate Control
Pic #2.....using the needle nose
On one bolt, had to use the needle nose to carefully remove the bolt, as the bracket is in the way and I couldn't find a thin wall socket to do the job. It worked great to undo and to reattach.
Pic #3....exposing the board, again this is not the inner board where you clean the contacts...dummy me!!!
Pic #4....pencil erasers to clean the contacts
You can see the difference between a clean eraser and one that has been over the contacts....
Pic #5....q-tips used
here you can see the q-tips that were used to clean the contacts with alcohol after using the pencil eraser. I went around the board at least 3 times with the eraser and alcohol to make sure everything was as clean as could be. Also cleaned the pins. You will notice the dirt on the q-tips, they were dipped in alcohol to do the job. The video shows removing the ribbon from the board, but I did not see a need to do that, so I left it in tact.
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-19-2015   #2
Roadster
Roadster's Avatar
Default Re: Have your Climate Control Buttons ever not respond to your commands???
Pic #6....foam displaced in top air vent
Pic #7....radio and Climate Control out
what a dusty mess in there....cleaned everything up, looking clean...
Pic #8....installation of units (newly purchased Bose) and foam glued
Pic#9....job complete and everything working just fine
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-19-2015   #3
RussMcB
Thank you, Tom. I think I need to do that. Mine were acting funky recently.
Old 07-19-2015   #4
Roadster
Roadster's Avatar
My pleasure Russ, glad it will get you motivated to get it done....it's too hot not to have the system working correctly....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-20-2015   #5
lbszr
lbszr's Avatar
Interesting. Mine has done that also. If I leave it alone for a while. It seems to wake up and work, so I thought it was some type of processing problem, but I might have to try this.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 07-21-2015   #6
Roadster
Roadster's Avatar
Yes, mine also was a work and not work problem. Then it just stopped responding. Worth the time to do, just watch the video. Hopefully it will work for you, it acts like a new system....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-21-2015   #7
Is there a link to the video? Im not sure which parts you are cleaning from the pics?
Old 07-22-2015   #8
Roadster
Roadster's Avatar
Finally figured out how to post the link. As I mentioned above, dummy me forgot to take the pic of the control unit with all the buttons apart. As you will see in the video, very easy to do....The only pic is #3, where the control "head" on the right is shown from the back. The large board on the left was just inspected, I did not do anything with it. Again I felt no need to unplug the ribbon.
Climate control repair C4 Corvette
https://www.youtube.com/watch?v=KBeqA1n9q9A
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 07-22-2015   #9
Thanks Tom that cleans up the mystery so to speak.
Old 07-22-2015   #10
John Boothby
John Boothby's Avatar
Mine was iffy when I bought the car 10 years ago and I had read in this forum about cleaning the contacts. I took mine apart and cleaned the contacts and it has worked flawlesly ever since. Easy job also! Also Dr. Don did his number on my radio/cd/cassett and speakers. Also replace the power antenna with a complete new unit.
JB
1990 #148 Red/Saddle
Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice
:cheers:
