06-27-2015 | #1 |
steering noise/issue
I am experiencing some sloppyness in my steering right at top center of the wheel. It feels as if it has a few inches of play (not responsive enough, my 1994 LT1 was definitely more responsive hence why i think something is worn) and it is more noticeable at higher speeds. Also i turned the wheel back and forth with the car off and something is making a knock noise. My brother thinks it may be a worn steering box. Anyone have any experience or advice with these symptoms?
06-27-2015 | #2 |
Re: steering noise/issue
You may want to check the steering rod coupling and tie rod ends. You have rack and pinion steering (no steering box) and yes it can ware out.
06-27-2015 | #3 |
Thanks, how would i go about checking that to see what to replace?
06-27-2015 | #4 |
Have a buddy move the steering wheel while you check for whats lose or where the play is. Do it with and with out the car running. Jack up each wheel and check for play.
06-27-2015 | #5 |
If it turns out to be the rack and pinion, turnone-steering.com seems to have a good reputation for rebuilding. I found a rebuilt on at rock auto without a core. I'll be sending my original to turnone.
If I rock the steering wheel with it not running, mine has a knock from in the rack with the old and rebuilt, but the play is gone.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT] [FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT] |
06-28-2015 | #6 |
maybe the knock is normal for this rack and pinion but I am almost certain the play is not. The response should definitely be sharper than what I am experiencing. I have to check everything out/jack up the front 2 wheels when I have time.
Is the steering in our ZR1s any different than the base C4? and is rebuilding our rack and pinions the only option? (no new offered?) Turn-one steering looks great but I am in NJ. If I have to pay to rebuild the system Id rather just bring the car somewhere in NJ instead of taking everything apart and paying for shipping twice. Does anyone know of good shops in or around NJ? Last edited by Johnny5; 06-28-2015 at 01:02 PM. |
06-28-2015 | #7 | |||
My wife bought the ZR-1 in order to have a faster C4 than her '88 Z51; we were pretty surprised at the difference in steering. I have come to believe this was intended to keep their well-heeled new car buyers from twitching off the highway at 175mph. We switched the rack right away and it was still lacking the crispness of the Z51 car. I picked up one of the "hockey pucks" and swapped it, much more direct now. Anyway sorry for the long post but a lot of that journey started when I noticed the rag joint had play in it... on edit after your edit: In the highly unlikely event you need to get your rack rebuilt, I would not hesitate to send the rack to Turn One. You can probably get a parts store re-man put in at your corner garage, but IMHO "There be dragons there". HTH, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] Last edited by batchman; 06-28-2015 at 01:13 PM. |
06-28-2015 | #8 |
If it's not the simple things. There is the possibility the rack preload adjustment needs adjusted back to factory specs. I tried it on mine before replacing the rack and it didn't help the play, but you never know, free to try. The adjustment is hard to gain access to.
Mine was really bad, it started with a catch that could be felt while turning the steering wheel. It even started wheel shimmy in hard turns on a road track. Corvette Recycle has NOS rack if you want new. $750.00.
06-28-2015 | #9 |
my car only has 28k miles so i bet it is something stupid like the lower balljoint on the control arm or some play underneath that plastic cover. Im going to jack it up next weekend. I hope it is not the rack and pinion.
06-28-2015 | #10 |
i am coming from a 1994 corvette lt1 with the adjustable suspension, maybe the steering in those cars are just felt more crisp and direct than the zr1. I guess I'll find out Friday (im off work ).
