Old 06-08-2015   #31
Billy Mild
Default Re: Running hot?
I let the ZR-1 sit over night then disconnect the Oil Cooler Adapter (one 6mm x 1.0 x 35 mm bolt in center) without disconnecting the Oil Cooler Lines from the adapter. This makes it much easier to lift the Drivers Side of the Shroud first. When the Drivers Side is cleared, lift the Passenger Side letting the shoud tab under the AC lines bend and pop up.
The Shroud really comes off fairly Easy but you just have to apply a little pressure and lift it off in sequence Drivers Side then Passenger Side.
On the Installation the reverse installing the Passenger Side bending the Tab down inside the AC Lines and then the Drivers Side lowering onto the radiator. I did not cut the Shroud in any way.
Yes it does point to an airflow issue.....Daryll (Goldcylon) I recall installed higher flow rate fans and others have installed Aluminum Racing type Radiators. But what you describe is normal for the ZR-1 with Stock Radiator. To keep the Coolant Temperatures below 225-230 deg F on HOT (100+ deg Ambient) idling in traffic one MUST turn off the AC. And even then it is sometimes difficult to keep the temperature down. It is amazing that just a little air flow (20 mph) will usually start bringing the Temperature under control.
Like Mike and Jerry and others have said ....You MUST clean the Radiator, AC Condenser, AND Oil Cooler to assure Air Flow.
I will go ahead and replace the thermostat just for good measure when I do this.
Old 06-08-2015   #32
Fact that your coolant temp on highway was fine suggests your thermostat is functioning properly. That being the case you might want to avoid unbolting the thermostat housing. When I unbolted my thermostat housing about 8 years ago bolts were corroded and led to stripping the threads on the thermostat housing. Unless you are willing to take the risk and prepared to have it helicoiled, if the threads get stripped, I would leave the thermostat in place. Just my thoughts.
