Old 05-13-2015   #1
Johnny5
Default Question converting new secondary actuator solenoid
Anyone buy a new sec actuator solenoid from Jerrys and have to modify it to fit? What is involved? A step by step would be much appreciated as i have to pull the plenum and replace this part but could not find an original.
Johnny5 is offline   Reply With Quote
Old 05-14-2015   #2
mike100
Default Re: Question converting new secondary actuator solenoid
GM has used that vacuum solenoid in a few different applications so most likely only the mounting bracket is a little different.
Old 05-14-2015   #3
RICHARD TILL
The mounting bracket is different. It`s easy to change. Just bend the tabs with some pliers and replace the bracket with yours. Duralast is the brand and EVS 34 is the part number.
