03-28-2015 | #1 |
F-Body wheel bearing installed
I needed new front wheel bearing and after looking around the F-Body wheel bearings part no: SKF BR930186 is suppose to be one of the better options for a tough front wheel bearing that is better than factory.
Installation on both sides took me about 1 hour. Only difference is you insert the bolts from the rear and nuts in the front due to the threads on the bearings. Either that or tap them out. Hope this helps with a option for the C4 ZR-1. Edit, this bearing will work for 1991 - 1996 Corvette only. Before: After Time to get that alignment, put some miles on the Z, and have some fun!
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* Last edited by Karl; 03-29-2015 at 03:08 AM. |
03-29-2015 | #2 |
Re: F-Body wheel bearing installed
Good to know, Karl!!!
Is this a GM part#, or did you get it somewhere else??
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 03-29-2015 at 06:02 AM. |
03-29-2015 | #3 |
I mentioned to Karl that if it were me that I'd certainly consider the F-body for a '91+ car. The confirmation was done years ago and I guess the monetary savings would depend upon the brand, warranty and vendor for the bearing. It's good to see that it worked well for Karl and his install times are what I would consider reasonable. Once done of course the next pair would be somewhat less time consuming.
The bearing used for the install is a '93 - '02 F-body and the "branding" is "your choice"! I believe that if a person had a '90 or earlier car which had an ABS defeat or the ABS was just broken that the bearing could be used also. I haven't had a pair of them "side-by-side" to check but I likely will. I'm not interested in the use for the '86 - '90 with ABS, but rather it would be maybe a less expensive/easier to procure bearing that could be used for the '84 & '85 cars that don't have ABS. A friend has an '84 and he'll likely do and confirm the install. I'll pass on what I determine after I have one of each in a "side-by-side". Last edited by WVZR-1; 03-29-2015 at 09:18 AM. |
03-29-2015 | #4 | |
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 03-29-2015 at 11:02 AM. |
03-29-2015 | #5 |
skip to post #11
http://www.thevettebarn.com/forums/c...tte-topic.html |
03-30-2015 | #6 |
Read a couple posts mentioning the SKF930186 F-body fits the 91-96. The 90 has no traction control or slip recovery, but will these parts fit a 90, is the question??
Soon as I know (or someone else chimes in), I'll post it.
03-30-2015 | #7 | |
Buyer beware until somebody tries it I guess. I know some of you guys have both years in your collection, maybe one of them could try it out and just keep the spare parts just in case the 90 is an oddball fit. Last edited by mike100; 03-30-2015 at 11:30 AM. |
03-30-2015 | #8 | |
If the ABS is active and working I see no real advantage to even considering the use of the F-body assemblies for the '90. The F-body I thought would be of particular interest to maybe the '84 - '85 owners maybe. No auto parts store near me had both the assemblies involved on the shelf for comparison "first-hand". I could likely determine the requirement if I knew the dimension from the back of the mounting flange(to knuckle/spindle) to the tip of the ABS reluctor wheel of the '90. This link takes you directly to the back-side view of a '90 and earlier assembly. That's the dimension that interests me. http://www.carid.com/timken/wheel-be...FUoV7Aodbn4Anw |
03-30-2015 | #9 | |
The only difference on the 91-96 vette vs f-body hub bearing is the threaded hole vs. non-threaded. And 1/2 to 1/3 the cost of course. |
03-30-2015 | #10 |
So does anybody know why they say you can't do the later parts on 90 and below C4's? I'm of the thought that there is a very specific reason or people wouldn't be listing them as for use on 91-up.
