Old 07-30-2005   #1
RiceEatingZR1
RiceEatingZR1's Avatar
Default High Speed Fans
Does anyone know where I can get replacement Fans that will fit in the stock fan shroud? I understand that I would have to redo the wiring and all but I want to replace the fans with a high speed ones to keep the car running cooler and still look stock.
RiceEatingZR1 is offline   Reply With Quote
Old 07-30-2005   #2
redvett94
Default
If you having a cooling problem than you should look at the whole system. Clean the radiator in & out. Make sure the pump & thermostat are OK and air dam is not missing. Debris in between the rad. & condenser is the biggest problem.
redvett94 is offline   Reply With Quote
Old 07-31-2005   #3
Hib Halverson
Default
I am unaware of any "high rpm" electric motors for the fans. Actually, when the engine computer commands the fans to high, they flow a hell of a lot of air---provided both are working properly.
I agree with the second post in this thread....if your ZR-1 is running what you feel are high coolant temperatures, then you need to address the issues raised in that post.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 07-31-2005   #4
RiceEatingZR1
Default
Thanks guys. I had planned on taking the Rad out to clean it anyway I was just going to see if I could get it cooler with higher RPM fans or motors. I am thinking of a 180 stat as well.
Old 07-31-2005   #5
redvett94
Default
You will have to make your own 180 thermostat since no one makes them anymore.
Old 07-31-2005   #6
RiceEatingZR1
Default
Doug Rippie has them on his Web site http://www.dougrippie.com/ I was going to call and see if he still made them since he did the Chip that is in my car. however if he doesnot make them anymore how would I make one?
Old 08-01-2005   #7
zrwon.ca
zrwon.ca's Avatar
Default
I always buy mine at the GM dealer and it's always been a 180, I bought 3 over the last 8 years, the last one was a year ago.
I found 2 of the old boxes with the old thermostat in them and the P/N is 10135627 and is an AC Delco box and the thermostat is a 180, I tested it on the stove and it is open at 180.
Al
zrwon.ca is offline   Reply With Quote
Old 08-01-2005   #8
redvett94
Default
Al
The 10135627 according to Lotus starts to open @180 and is fully open at@ 197-200deg.
I believe that Robertshaw made a 180 in 1991-2 but not many were made. Making your own that opens fully is what i ment. Mine opens fully at 185.
