Old 07-28-2007   #11
Ccmano
Ccmano's Avatar
Default Re: ACCEL injectors
Originally Posted by Jagdpanzer
Do the same PN ACCEL injectors work in all ZR-1 engine model years?
Yes, ACCEL 21#* High Impedance FUEL INJECTORS #150121
Hans
90'ZR-1 #1461 Red/Black
05 C6 Z51 Red/Black Sold
Old 07-28-2007   #12
george henry
george henry's Avatar
Ccmano's injector description is good but he has them reversed. The primaries seal to a larger o-ring in the injector housing while the secondaries seal to the small o-ring at the bottom of the injector. All sixteen use Accel # 150121. Remove the small o-ring at the bottom for primary injector use. See you at 180.
1990 #1507 Black/Grey/flowmaster-DRM chip
george henry is offline   Reply With Quote
Old 07-28-2007   #13
Ccmano
Ccmano's Avatar
Thanks for the correction... couldn't remember which was which.. although, other than removing the primaries it really doesn't matter.
Hans
