Runs great until 5000 RPM then terrible.
Manual says "System Lean Monitor" Does this mean the O2 sensor is bad? I did not see a diagnostics chart for this code in section 8. 91 with the usual mild mods, secondaries pulled, 37K miles. I did a search for "Code 55" but the search engine says 55 is too common. Thanks |
![]() Join Date: Mar 2007
Check fuel pressure, might have a bad pump or hose is off pump
Going to reset and drive it again. If it happens again I will chk FP.
Thanks Lee |
![]() ![]() Join Date: Aug 2005
![]() Join Date: Aug 2007
Check Fuel Pump 2 fuse which is located on the auxiliary fuse panel. On the passenger footwell, remove the cover and look under and you will see a small panel with some fuses. One is marked FP2, check it.
If Fuel Pump 2 does not run, you don't have enough fuel on Full Power mode when the engine is WOT and this causes the lean problem. |
#6 | |
![]() Join Date: Jun 2005
Generally, it means your engine is running out of fuel at WOT. Be careful with that and no secondary port throttles. You can burn pistons and valves in a heartbeat. Either the fuel filter is restricted, the fuel lines are restricted or the secondary fuel pump is not working.
We don't need no stinkin manuals
