Old 01-26-2015   #1
Scrrem
Scrrem's Avatar
Default Thottle Cable Adjustment?
While doing our final checks yesterday before I fired up the new motor, it was discovered that my throttle plates are not opening fully when I mashed down the accelerator pedal. Is there any kind of adjustment on the cable for a 90? The later cars have an ajustment up by the ASR, I didn't see anything on mine.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 01-26-2015   #2
Default Re: Thottle Cable Adjustment?
Originally Posted by Scrrem View Post
While doing our final checks yesterday before I fired up the new motor, it was discovered that my throttle plates are not opening fully when I mashed down the accelerator pedal. Is there any kind of adjustment on the cable for a 90? The later cars have an adjustment up by the ASR, I didn't see anything on mine.
Rich
This may sound stupid but have you checked to make sure cable is fully seated in throttle cam? Guess why I know that?
Old 01-26-2015   #3
efnfast
Well, lets hope the car has gobs of power with the throttle only part way open. 'magine when it opens all the way!
Old 01-26-2015   #4
Scrrem
Scrrem's Avatar
It seamed to be when I re-installed it but I'll check it again.
Rich
Ron Davis Radiator
Old 01-26-2015   #5
You must have stretched the cable with all that pedal mashing!
Should be able to rig something at the pedal.
Old 01-26-2015   #6
Demps
Demps's Avatar
There is on a 95. I'm pretty sure the 91 has one too. Don't know about 90 but here goes: Trace cable and see if it has a block type section. If so, there will be a hard plastic plunger or release. Depress pedal all the way then depress the plunger. I'll look in svc manual.
Ted
Old 01-26-2015   #7
Ted I don't believe the plunger adjustment on the throttle cable came out untill ASR. None on my 91 .. 93 has it.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 01-26-2015   #8
Demps
Demps's Avatar
Concur. No talk of adjustment in 90 svc manual. Just references no binding and seat correctly in pedal. There is however description for cruise.
Ted
Old 01-26-2015   #9
Ted,
That's only on ZRs w ASR. 92-95. 90-91 are twin cables instead of 1.
