Old 01-18-2015   #11
Default Re: Big brake conversion - finally complete
amazing Yun!!
Congrats!!
Old 01-18-2015   #12
Scrrem
Scrrem's Avatar
Awesome Yun! I know it's nice to have those big brakes up front!!
Congrats
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 01-18-2015   #13
Ok, but I was asking about wheel offset and if the rotor hats change it.
I am not running stock A-mold so cannot guarantee front OEM A-mold would clear. I know rear will clear because we tried A-mold after the brake conversion.
Old 01-18-2015   #14
Demps
Demps's Avatar
SL-6 with 13" rotors are largest for A-molds. The hats are 'thin' (appropriate) enough to keep spacing stock-like. There is an older Wilwood front kit that spaced the front track out about 1/2" per side. I have it on my 415.
Ted
Old 01-18-2015   #15
I ask because I had 2 piece Brembo rotors that moved wheel out by .5".
Old 01-18-2015   #16
Superlites are narrower than c6 Z06 calipers (probably narrower than Brembos also). Come to think of it, Mike Geier runs the same set up with 13" rotor with Fikse FM 5s.
Old 01-18-2015   #17
Do the rotors affect stock offset?
They shouldn't...
I have the SAME kit but with 13" rotor rings
Old 01-18-2015   #18
I'd like to find rotors that weigh less than the Z06 rotors but don't want to mess w the offset.
Old 01-18-2015   #19
Then you will need to look at what Wilwood offers for a stock replacement for the Z06..
get a 2 piece with Aluminum hubs
Old 01-19-2015   #20
zrss
Rippie sells two piece C6 Z06 rotors that weigh about 9 pounds less than stock.
zrss is offline   Reply With Quote
