Old 10-30-2014   #21
Default Re: Hopefully not catastrophic failure?
I'm going to suggest fuel injector connection for injectors. Made in the usa life time warranty and a friend to the registry, which I hope you consider joining. Hope to see you at carlise also
Old 10-30-2014   #22
Polo-1
need to take apart first. You might already have FIC, RC's ,..... who knows yet. If it ran good before the crap out....... Wait to pull apart first.
Can you tell, I don't like putting parts at it till I have seen it apart.
These LT5's are pretty dang tough. Mine has had GM orange antifreeze in it ( big no ) and has been hit with 175 shot N20. Stock top end and still has the factory head gasket in place. Dang tough motors.
Old 10-31-2014   #23
ghlkal
ghlkal's Avatar
Originally Posted by MikeSuke View Post
Another question, not knowing the age condition of the injectors, this sounds like a good time to replace them. Would that make sense if we are already in there?
Yes, if needed, but injectors are a $750 investment. So, as others said, make sure you need them first.
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 10-31-2014   #24
$650 actually but not something to jump into if not needed
Old 10-31-2014   #25
Yes, I guess I blocked my episode w this. What a pain! However, even if u block IH, you still need to seal head/IH interface. I use Permatex #2 around that area only.
Dittos
After porting, there was about 1/8"-3/16" between the water and the intake runner. I was using a gasket from another vendor, so I switched to the ones available at Jerry's Gaskets, and I too used Permatex #2 around the water port.
Hope this helps.
Paul.
