10-22-2014 | #31 |
Re: FIX ILEAN (she leans too much)
IIRC,the factory spring rate on my stock 94 spring was 430lbs.
Clint & Sherry 1994 ZR-1 White/Red #152 (sold) 1991 ZR-1 Callaway Aerobody #1332 (sold) 1990 ZR-1 Red/Red #952 (sold) 2002 Z06 Torch Red/Mod Red widebody |
10-23-2014 | #32 |
Here is the ever helpful C4 suspension chart...
http://www.corvetteactioncenter.com/...usp_chart.html The rates are in n/mm and can be converted to lb/in here... http://www.convertunits.com/from/pound/inch/to/N/mm I checked a few of the numbers against the Corvette Specs book, which shows a mix of lb/in and N/mm depending on year and the match using the converter. Anyhow, stock rates on a '91 ZR-1 is 549 for the front, 228 for the rear. '92 is 431 and 188. Chris Last edited by csavaglio; 10-23-2014 at 09:40 AM. |
10-23-2014 | #33 | |
