View Poll Results: Which oil do you use? | |||
Amsoil | 79 | 22.13% | |
Castrol | 19 | 5.32% | |
Champion | 0 | 0% | |
Chevron | 0 | 0% | |
Conoco | 0 | 0% | |
Citgo | 0 | 0% | |
Havoline | 1 | 0.28% | |
Interstate | 0 | 0% | |
Kendall | 1 | 0.28% | |
Lowe | 0 | 0% | |
Marathon | 0 | 0% | |
Mobil 1 | 224 | 62.75% | |
Motorcraft | 0 | 0% | |
National | 0 | 0% | |
PennZoil | 4 | 1.12% | |
Quaker State | 3 | 0.84% | |
Redline | 10 | 2.80% | |
Royal Purple | 11 | 3.08% | |
Valvoline | 5 | 1.40% | |
Voters: 357. You may not vote on this poll |
Thread Tools | Display Modes |
10-20-2014 | #111 |
Re: Which oil do you use
Here in Barcelona (Spain) we use in our ZR1:
Mobil 1 5W50 Peak Life API SN / SM / SL ACEA A3/B3, A3/B4 API CF Mobil 1 5W50 Peak Life aproval: VW 501 01/505 00 PORSCHE A40 MB-Approval 229.1 / 229.3 BMW High Performance Diesel Lexus LFA Factory Complete Specifications: Valor Viscosidad, cSt ASTM D445 @ 40 º C 108 @ 100 º C 17,5 Índice de viscosidad 180 Sulfatada Ceniza,% en peso (ASTM D874) 1.3 El fósforo,% en peso (ASTM D4951) 0.1 Punto de inflamación, º C (ASTM D92) 231 Density@15.6 º C g / ml, (ASTM D4052) 0,85 Número Total de Base (ASTM D2896) 11,8 MRV a -35 º C, CP (ASTM D4684) 29.244 Viscosidad HTHS, mPa • s @ 150 º C (ASTM D4683) 4.4
Toni Pujol 1994 Black on Black ZR1 #080 my brother is Ramon (93ZR1Barcelona) 1993 Black on Light Grey ZR1 #317 Want to belong to 500+ HP ZR1 club 350 Engine ready to assemble. Full porting done (Heads, IH, Plenum,TB63, Air Horn) Pete reground cams. Fidanza Borla+SW Heders+SW Xpipe C5 Z06 front Brakes DeWitts Radiator Home made shrowd + 2 speed Motorcraft single fan. Mopar 4.10 pinion & ring Last edited by Toni94ZR1; 10-20-2014 at 06:37 PM. |
05-05-2015 | #112 | |
Sound good. I don't think we have that Mobil1 in the US. What kind of PPM does it have for phosphorous and zinc? When are you and your brother coming out to C4/ZR-1 Gathering at BG again? Take care and Aloha,
05-07-2015 | #113 |
Wow!
Those pole results... A stunning endorsement of ExxonMobil's marketing of the "Mobil 1" brand. In fact, that the three highest poling engine oils all come from companies which market very aggressively speaks volumes about how oil companies market products and what consumers believe about oil company advertising.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 05-07-2015 at 11:55 AM. |
05-07-2015 | #114 | |
Keep in mind that no LT5 needs an SAE 50 engine oil unless the duty cycle is severe in very hot weather. For normal street use and even street high-performance use, I would not recommend a 5W50 in an LT5. Also, LT5s are OHC engines with direct acting bucket tappets. The loading on the camshaft lobes and lifter faces are far less in an OHC valve train than they are in a pushrod valve train, thus, there is no need for high levels of ZDDP.
05-07-2015 | #115 | |
05-07-2015 | #116 | |
05-08-2015 | #117 |
Wow! Now I am seeing double.
05-08-2015 | #118 |
05-08-2015 | #119 |
08-10-2015 | #120 |
The Truth About Zinc & Motor Oil
http://www.drivenracingoil.com/news/...-in-motor-oil/ Zinc Versus Detergent In Motor Oil http://www.drivenracingoil.com/news/...-vs-detergent/
[IMG]http://i119.photobucket.com/albums/o128/wb9mcw/SIG-2.jpg[/IMG] [IMG]http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif[/IMG] [FONT="System"][SIZE="3"]"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC " We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln[/SIZE][/FONT] |
