Old 10-19-2014   #1
efnfast
Default headlight bushings
So the drivers side was straight forward enough, but the passengers side, I cannot get the gear out of the case. On the passengers side, the pinned end of the shaft goes through the cover I removed, the shaft does not penatrate the other side of the cast. The shaft and gear won't come out. Help.
Old 10-19-2014   #2
efnfast
Default Re: headlight bushings
Got it.
Old 10-19-2014   #3
Originally Posted by efnfast View Post
Got it.
But....But....we did not get it
What happened and how did you fix it?
Old 10-19-2014   #4
efnfast
The large plastic gear has a shelf? on the side of the gear. On the drivers side the shelf is on our side of the worm gear on the motor. On the passengers side, the shelf is behind the worm gear. I pitched the large gear as much as possible, to twist the shelf out from behind the worm gear. Plus I put a drift pin through the hole in the shaft and pulled hard.
None of the youtube videos show the passengers side.There are also three spacers that a lot of the videos don't address.
