Old 07-09-2014   #1
Default check your interior screws
yesterday I had a chance to do some interior cleaning and decided to check and make sure the visible screws were nice and tight. Turns out a hand full were so loose they were about to fall out! Took a screw driver to all of them and made sure they were all tight.
Old 07-09-2014   #2
Default Re: check your interior screws
That is good advice for ALL Nuts and Bolts on the LT5 as well including the oil pan and water pump
Old 07-09-2014   #3
So true Kevin. I did an interior conversion this winter and the halo trim screws were already backing out.
Old 07-09-2014   #4
that's the one that was almost falling out on mine. also found one that was stripped out on the PS rear hatch trim. I know what I'm looking for at carlisle
Old 07-10-2014   #5
Racinfan83
Yeah a bunch of mine were gone when I got the car. Found some at Sears Hardware that look almost the same and bought several in different lengths to replace. While they aren't OEM - unless you are a NCRS judge you wouldn't notice...
Old 07-10-2014   #6
And, I found a loose nut behind the steering wheel...
Old 07-10-2014   #7
8cam
I had a big vibration that appeared and the car wasn't happy in the curves. I wasn't sure what happened, but I didn't like it at all and all sorts of bad scenarios went through my head. Then I discovered one of the windshield header bolts that holds the top on had come loose...very loose. Tightened that back up, vibration gone and car is solid again.
Old 07-10-2014   #8
pretty sure we all have that issue
Old 07-10-2014   #9
A small dab of silicon sealant on the threads will help keep them from coming lose or corroding.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 07-10-2014   #10
My problem isn't loose screws. When I do a project (say like wiring in my cutout switch) I always seem to have a couple of screws left over. Been doing that since I first disassembled a lawn mower when I was a kid. Anyway it still ran. Never did figure out where they went. --Bob
WARP TEN is online now   Reply With Quote
