Old 06-11-2014   #1
KGV
KGV's Avatar
Default G48 antifreeze in Germany
Hi,
I have read that the green Zerex antifreeze is recommended for the LT5, but this is not available in Europe. The GM dealer near me has a G48 type antifreeze. It looks green/blue, and it appears to be equivalent to the 1825M GM specification.
Has anyone used this, or should I play it safe and order the Zerex Original Green antifreeze.
Thanks,
Ken
KGV is offline   Reply With Quote
Old 06-15-2014   #2
KGV
KGV's Avatar
Default Re: G48 antifreeze in Germany
I decided not to take a chance and I ordered three gallons of Zerex Original Green via Amazon. The antifreeze was 35€ and shipping 54€, but worth the price for the safety factor. I believe I need two gallons of the concentrate but I ordered one more in case I need to add a bit.
Ken
Old 06-15-2014   #3
mike100
I would think that there would be some other kind of "conventional" coolant for sale for older automobiles that is a common brand, but I do not know what those brands are in Europe.
One could reference the chemistry through an MSDS maybe?
Old 06-15-2014   #4
KGV
KGV's Avatar
Hi,
I had found these charts on the Valvoline website. The G48 corrosion mass was double the Original Green, and the G48 also has 30 ppm of phosphates.
The order from the US only tales 7 to 14 days, so I decided to get the Original Green antifreeze.
Zerex - Typical Physical Properties vs G48 Original Green
Antifreeze Glycols mass % 93 96
Corrosion Inhibitors mass % 4.0 2
Water mass % 3.0 2
Flash Point °F/°C 250/121 250/121
Weight per gallon @ 60°F/16°C lbs./KG 9.3818/4.2555 9.363/4.247
Silicon PPM 250 250 max.
Phosphates PPM 30 max.
Thanks,
Ken
Old 06-15-2014   #5
nelson007
nelson007's Avatar
Hallo Ken,
There is GM dealer near my house in Augsburg. I can't remember the name of the city buts its near Augsburg. There another GM dealer in Russelsheim, they were able to get me parts i needed for my 69 vet a couple of years ago.
Nelson007
Ken[/QUOTE]
WAZOO MEMBER
1993 #124 Ruby
1994 #??? Red/Black
1995 #061 Black/Red
2012 ZR1 Preproduction
