Old 06-11-2014   #1
tf95ZR1
tf95ZR1's Avatar
Default Oil & Flat Tappets
I think this is applicable to our engines:
http://www.superchevy.com/how-to/cor...-down-engines/
Old 06-11-2014   #2
Default Re: Oil & Flat Tappets
Yes, I've experienced a cam that went flat; on a flat tappet SBC, actually. And, here's a link to an article by Marc Haibeck with regard specifically to the LT5 and recommendations for our engines.
In short, Amsoil AMO 10W-40 has the ZDDP levels originally available and spec'ed for the LT5. If not AMO, then something equivalent with ZDDP levels sufficient to support not only our flat tappets, but those long double row chains as well.
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 06-11-2014   #3
PhillipsLT5
PhillipsLT5's Avatar
Article called for AMO 10/40, thats what Marc suggests
Old 06-14-2014   #4
rkreigh
loads on the lt5 cam buckets are relatively light
with the light valves and relatively small light springs and the LT5 quality harnened parts we don't see too much of the stock stuff going flat
I use the mobile gold top extended with more zddp
but the amsoil stuff is a step up and better
but for sure the slippery stuff helps
95 390 LPE ZR1 (505 rwhp)
Old 06-14-2014   #5
pantera1683
How much is the Amsoil AMO 10/40 going for these days?
Old 06-14-2014   #6
About $8-10 per quart, small price to pay for piece of mind.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 06-14-2014   #7
pantera1683
Has anyone actually ran into any problems using more common off the shelf oils such as Mobil 1?
Old 06-14-2014   #8
Ran Mobil 1 for the last 11 years in the 91 with no issues, I did change to Amsoil this year after Marc did the upgrades.
Steve
1990 Red/Red #1473
Old 06-14-2014   #9
When you say MOBIL 1....
C-LINK
90 #1202
Sans secondaries
Old 06-14-2014   #10
WVZR-1
C-LINK
The majority of the Mobil1 product purchased "across the counter" isn't in your "LINK"!
The product most see and I expect use is in the mobil1.us left column either the M1EP, or the next conventional M1, the rest is there also:
http://www.mobiloil.com/USA-English/...Oils/Oils.aspx
