06-02-2014 | #31 |
Re: Why not just remove thermostat?
FYI, Marc Haibeck's chip typically turns on both fans at 205 degrees. I don't recall my car showing anything higher than about 208 on a hot day, maybe 210. -- Bob
06-02-2014 | #32 |
Is that reading HVAC or analog (dash) gauge?
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-02-2014 at 10:54 AM. |
06-02-2014 | #33 | |
OBD2 vehicle with clutch fan. The temp gauge is constantly moving in a steady state cruise, I', assuming the stat is opening and closing? The stock stat deos not show any cycling on the gauge. Further evidence of a temp change is the lower heater output when the lower temp stat is installed. Closed Loop Fueling enable has a stock setting of 56.25ºC or 133.25ºF. Much lower than the LT5's. In Tunercat's OBD2 I can adjust the Closed Loop Enable temp to whatever I wish. There is a point where running an engine too cool increases cylinder wall and other wear.
peace Paul ZR-1 Net Registry Member #1494 Last edited by Hog; 06-02-2014 at 10:48 AM. |
06-02-2014 | #34 | |
My point is that just because an OEM cant get a car to pass emmisions testing with lower temps, doesnt necessarily mean that a car with lower operating temps wont be able to pass a garden variety emissions test at the individual owners/driver level. However, if a car had top be "sniffer tested" and the car was struggling to enter Closed Loop because the engine was running too cool, I can certainly see that causing issues in passing. Graham Behan would have extensive experience with OEM and aftermarket emmisions testing as Lingenfelter PE had a couple LT5 emmissions compliant packages, and they even had an emissions compliant 550hp SAE net, 705 lb/ft torque from 605 cubes BBC engine package for their Suburban packages. If they can get a dirty BBC to comply with emmissions laws, and "tuned" LT5 shouldnt be too hard. When we had the chassis dyno testing similar to California spec testing, I had 160º thermostat, longtube headers, aftermarket cats, EGR disconnected(but present to pass the visual) and the truck blew very clean.
peace Paul ZR-1 Net Registry Member #1494 |
06-02-2014 | #35 | |
I don't know that this will add anything useful to this interesting conversation. But, reading along, what gets written and what folks meant to say are not always the same. So, if that is the reason I got the impression that there was some confusion regarding some basic physics principals, I don't mean to be "speaking to the choir". But, for some perhaps majoring in sociology instead of science they might find something below worth using...maybe? Anyway... It's easy. What it "boils" down to is simple physics:
-with the relative difference in temperature between the heated medium, and the medium receiving that heatEverything - the whole discussion about cooler or hotter thermostats circles around these two physical facts (1&2). Putting a 160º thermostat in for summer won't make any difference to the equilibrium temperature if conditions dictate that point to be closer to 230º. No matter if you have a 160 or a 200º stat, if the conditions dictate 230º, THAT is where temp will stabilize, regardless of the stat design. Heat transfer efficiency for any given ambient air temperature can be increased by-
The thermostat rating will prevent heat transfer until the designed temp is reached. At that point, the thermostat opens and physics takes over. There is either enough surface area in combination with the differential between the radiator and the (air) temp surrounding the core to result in the temperature stabilizing when the thermostat opens, or NOT. If, for example, ambient air temps are such that equilibrium will be 230º, then temps will rise w/o regard to the thermostat setting (beit a 160º* or a 200º or whatever), rising quickly at first, and stabilize at 230º (in this example) until and unless there are changes in engine load resulting in a change in the amount of heat being given off. *The only difference in temperature rise on the way to say a 230º equilibrium between using a 160º stat and a 200º stat is the rate of temp rise in that window between 160º to 200º. That will be useful and desirable on a drag strip. But, on the street...not so much. A more practical temp, in terms of radiator size and cooling fan metrics, closed loop and fuel efficiencies, might be closer to 200º. AND, instead of bigger fans, having BOTH come on instead of the factory staggering arrangement is a better solution, I say from practical experience with that (Marc's calibration) arrangement. Just sayin... Paul.
06-02-2014 | #36 |
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-02-2014 at 11:35 AM. |
06-02-2014 | #37 |
Good post Paul^^
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx I just wanted to add a tidbit about possible thermostats and the modern EFI vehcile. On the LT1 cars and L31 trucks, in the 90's there were ECM recalibration devices sold for these vehicles. Acommpanying these devices were 160º thermostats in order to help the engines and their 10.5:1 c/r produce full power with leaner WOT a/f ratios and advanced WOT timing curves these devices instilled into the ECM calibration. If a lower temp thermostat only helped slow down rate of engine coolant temp increases(which they do after a cold startup) the lower temp thermostats these kits included, really would NOT help to prevent detonation/knock sensor counts by keeping engine coolant temps lower. JET Performance and Hypertech were to companies that provided products in which they woudl suggest or include lower temp thermostats as part of their Level 2 (more agressive) ECM/PCM calibrations.
06-02-2014 | #38 |
I think you're better off cleaning your radiator, in and out, to gain maximum cooling efficiency.
06-02-2014 | #39 | |
Radiator Debris Screens
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-02-2014 at 12:31 PM. |
06-02-2014 | #40 | |
Look at what Chevy found by doing the "flo-tie" on the Z28. Increase airflow by 3%. just from that amount of increased area.
