Old 05-29-2014   #1
Schrade
Default Yup - WIFE IS LOUD!!! (exhaust acoustics)
Jeff was right - THis thing is LOUD!
Outside sounds great. I let a neighbor do a lap around the block after he helped lock down clamps. Sounded great driving off; I couldn't hear it on the back side of the block.
Inside is a different story. What I'm not diggin' so much is drone. It's loud between about 1,200 RPM's, to about 1,800, give or take. Gotta' be way below 40 Hz...
So I'm thinkin' on a few things here, individually, or in combination, to 'interfere' with the harmonic resonance:
1) Pipe wrap the 2 sections where the resonator was, and the X-pipe.
2) New (or additional) sound material under the carpet interior. I stayed with the original material because it 'smelled' new when I uncovered it for Black conversion.
3) Fitting / welding in a free flowing resonator behind the X-pipe (or 2 individual units, space permitting)
Where's Jeff T here; Jeff - did you consider option 3 here? Seems it would be an easy task, if a resonator could be modded for 2 x 3" inlets / outlets...
Of course, option 'b' would work too - turn up the radio
What did you do to take the edge off of interior noise, without hampering exhaust flow?
Old 05-29-2014   #2
mike100
Default Re: Yup - WIFE IS LOUD!!! (exhaust acoustics)
Single outlet mufflers will quell the worst of the resonance. The oem resonator was for a slightly higher harmonic and not going to do a lot for the hatchback drone.
I hacked NPP exhaust tips from a C6 and made a control scheme for the vacuum actuation. You'd be surprised at how well it actually works even on louder muffler designs.
Old 05-29-2014   #3
mike100
Catalysts help a little too.
Old 05-29-2014   #4
Karl
Karl's Avatar
Get the high temp red RTV out. I had a couple of leaks at the collector area.
I plan on using sound deadening material on my interior.
I may also swap the b&b mufflers for the dynomax with the built in noise valve.
Old 05-29-2014   #5
Schrade
Any snappics of your hardware there Mike?
Karl - 'Get it out'? You mean 'get some hi-temp RTV put IN'? I can see how that might effect harmonics, but all the slip-joints are sealed now...
Old 05-29-2014   #6
Shrek
My first plan was a resonator or resonators in place of the X-pipe.
That is until she said "put the Flowmaster system back on"
So I had no choice but to go with her option on her car!!
Shrek is offline   Reply With Quote
Old 05-29-2014   #7
Karl
Karl's Avatar
Yes after putting some miles on the car the slip fit connectors began to leak exhaust. Certainly not loud enough to cause drone and resonance, but it became audible.
Old 05-29-2014   #8
KILLSHOTS
It's loud? Do you have mufflers on it? Is it a daily driver? Mine is wide open, except for the cats, and I can't wait to put headers on it so those "mufflers" are gone too. Still too quiet for me. Oh well, different strokes...
A resonator should help with sound but my understanding is that getting rid of resonance is a VERY difficult thing to do, unless you're installing a "complete" system, such as a Corsa. When we design our own, we can muffle sound but resonance is hit or miss. Best of luck with it, Schrade!
Old 05-29-2014   #9
Really not trying to be a schmart azz, but featured in the current edition of HOTB is an excellent article WITH PIX that Mike wrote, detailing the entire setup. That article alone is worth your $35 membership - which is required to see the magazine.
Just a thought....
Old 05-29-2014   #10
mike100
I may repost some form of the information in the HoTB write-up after it has had a chance to be exclusive for a bit longer.
Here's a video of it working on Stainless Works muffs:
