Old 05-15-2014   #31
Schrade
Default Re: New owner in Minnesota
Originally Posted by RyanChappel View Post
Driver's side middle drippage may be the infamous header stud leak.
The booth is off the hook...
Exactly to what do we refer here? The main 'hanging' stud; center of block perhaps?
Mine came out once, with the nut on the tip.
I got it set, when I got the D side headers locked in, but do I need to check for some sealing???
Old 05-15-2014   #32
4CamJon
Here are a couple more after the bake cycle outside the booth. The 55 is a friend of mine's that has a LS1 in it.
4CamJon is offline   Reply With Quote
Old 05-15-2014   #33
4CamJon
Once everything is back together I will put it up on a lift and try to figure out the oil leak.
Old 05-15-2014   #34
See this post for info on the header stud leak and how to get the stud off using double nuts.
http://zr1.net/forum/showthread.php?...ader+stud+leak
I need to do this on my passenger side it has been leaking for many years now - big PITA
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg
http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif
"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC
" We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln
Old 05-15-2014   #35
Originally Posted by 4CamJon View Post
It's a 80' tunnel that fits 4 cars at a time. We have 2 set side by side with a mix room between. We paint on average about 35-40 cars per day.
What business are you in exactly?
Old 05-15-2014   #36
4CamJon
I work for a wholesale auto auction company which has 65 US locations. We have a full line reconditioning shop with a 10 bay mechanic shop, a detail shop that does about 175 cars a day and the body shop which with more staffing can do up to 75-80 cars a day. Most repairs are 2-3 panels per unit.
Old 05-17-2014   #37
WVZR-1
Your car was done with the production product you use in day to day OR? I would assume your day to day production is all water-borne if so whose?
Old 05-17-2014   #38
4CamJon
We have used BASF waterborne in the shop since 2008. At the time our location was the first to go with BASF from DuPont products. Now our company uses them exclusive in the 45 sites that have a body shop. Out location is used by BASF as a Beta site to test new products all the time along with 3M which also uses us to test different tapes and adhesives and checking our Ford and Chrysler factory inventory for how well their emblems hold up.
Old 05-17-2014   #39
"to test new products all the time along with 3M"
What do you think of this new 3M product
see >> http://zr1.net/forum/showthread.php?t=22954
Old 05-17-2014   #40
4CamJon
Haven't seen that one before. I would be weary of taking it off.
We usually test things like different tapes, sandpaper, foam for the door jams and a cling wrap for inside paint booths to keep the walls clean. They like that they can have as many as 100 bake cycles a week in a production setting. We have also done large repaint projects for Chysler in the past 5 years when they have had paint issues at different factories. The last one involved complete repainting of 2000 Jeep's that had a clear coat issue.
