04-30-2014 | #1 |
Code 14 and low coolant level light related?
I have code 14 and the low coolant level Light on. I have checked connections to sensors and they are good. I am assuming I need a low level sensor for the header tank and a temp sensor (to ECM)?
[SIGPIC][/SIGPIC]1991 #0663 |
04-30-2014 | #2 | |
Re: Code 14 and low coolant level light related?
http://www.zr1.net/forum/showpost.ph...4&postcount=15 CTS for the ECM is under the plenum. Have you pulled the plenum? Do you have a FSM? 6E-A-36 & 37 and there will be some diagnostic and resistance values in there also. Last edited by WVZR-1; 04-30-2014 at 02:45 PM. |
04-30-2014 | #3 |
The sensor in the tank is not replaceable - you replace the whole tank assy.
Used to be about $50 at your local dealer.
04-30-2014 | #4 |
That is what I was thinking until I finally found a coolant level sensor for sale online. It doesn't screw in?
04-30-2014 | #5 | |
04-30-2014 | #6 | |
GM # 10157994 |
04-30-2014 | #7 |
I have a bunch of stuff you need off a '91.
Ted |
04-30-2014 | #8 |
