Old 04-27-2014   #11
Schrade
Default Re: AIR delete... Who's pulled it? Effect?
Could the AIR pump be ducted to vent underneath the plenum? Additional cooling?
I wondered about a PC tower fan rigged to pull air through the space...
Old 04-27-2014   #12
Default This is getting toooooo complicated
Lets NOT get complicated now.....
That is the reason to delete the Air Induction with Headers....it is just a jumbled up plumbing Air Induction Mess and you can get SW Headers without Air Induction ports and without EGR ports for example.
Will an LT5 run if it is NOT Intact
I know an LT5 will run if it has parts that are Jumbled/Kludged/Ripped
And......purty FAST too
Just having some harmless fun with the boys
Old 02-27-2015   #13
Blownrunner
I was running rich on all 4 passenger side cylinders, I assumed because headers were leaking allowing outside air in. It ended up being the air injection tubing, as there are a lot of joints with plastic hose clamps. Removed everything and installed brass plugs on the injector ports on the headers, problem solved.
Blownrunner is offline   Reply With Quote
Old 02-27-2015   #14
USAFPILOT
USAFPILOT's Avatar
I bought Stainless Works long tube headers and had them install the AIR and EGR tubes on them. Bolted right up to the factory AIR system and works as advertised. I chose to do that because the emissions equipment is supposed to be there to pass in TX, at least in Houston, TX. However, I am positive I could have deleted it and no technician that has ever tested my car would have known.
Old 02-28-2015   #15
edram454
edram454's Avatar
florida does not test emissions. no cats, no resonators, tiny mufflers and long tube headers. previous owner disconnected air system. car runs great.
ed ramos #3028
