Old 04-02-2014   #21
Default Re: Help Identify My Brakes
Those front hubs are thick, they push the wheel outward to allow clearance for the caliper.
the wheels (depending on the wheel) will still fit under the fender
Old 04-02-2014   #22
That was the issue when I had the Brembos. The hub was thick and moved the offset further out causing my Z06 wheels to extend beyond the fender opening.
The stock Z06 rotors rectified that.
Old 04-07-2014   #23
Originally Posted by emmvette View Post
Thanks, I'll call and PM. Also to clarify the parking brake pads are fine. So are the others for now. I just want to know how to change the pads on the fly so when I'm at a HPDE or AX and something needs attention I'm not learning how to do it in the parking lot....
The FM5 rims are 17" OEM sizes.
Would you post up a pic of this brake setup front and rear under the Fikses? I am considering the same setup
Tags
brakes, brembo
