03-14-2014 | #11 |
Re: Clutch Reservoir Empty
OK, so the slave is leaking.... On the 1990 it is hard "piped" in, not flexible tubing and the CAGS is in the way to put a new slave back in. How can you remove the CAGS cylinder? Can't get to the two nuts on it due to the angle they come at the trans.
[CENTER][SIZE=4][COLOR=red]1990 ZR-1 Red / Red[/COLOR][/SIZE][/CENTER] |
03-15-2014 | #12 | |
It turns out I could remove the two nuts on the Slave Cylinder and slip it out from the studs and down (the hard line will slip between the bell housing and drivers tunnel). The hard line has a rubber hose section about 12-18 inches from the hard line (a 12 inch more or less section of rubber hose between two hard lines). This rubber hose section allows the Slave Cylinder movement flexibility which allowed me to move the Slave Cylinder down below the exhaust pipe. I used a 13mm open end on the tube connection on the Slave Cylinder. Loosen that connection and remove the tubing from the Slave Cylinder. Now it you are saying the New Slave Cylinder is a bit different and cannot be installed as easy as the old Slave Cylinder was removed.....let me know as I will run into this issue myself next Tue when I receive the New Master Cylinder and New Slave Cylinder from Jerry
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-15-2014 at 01:11 AM. |
03-15-2014 | #13 |
Got the replacement one from Jim @ powertorquesys and he helped me put it in; the new one has a bleeder which makes it taller and a little more challenging to install, but it did go. My aftermarket exhaust was in the way and caused some grief along with the CAGS sticking out in the way. If I had to do this again; I would probably drop the exhaust first as it caused the job to take an extra couple hours.
We decided to go ahead and have Jim rebuild the master as well so I won't have to worry about the clutch hydraulics for quite some time. So it is now pulled out. I'd still like to know how the heck the CAGS can come off. I guess everybody just disables it and leaves it on. If my trans comes out - I'll pull it off without question.
03-15-2014 | #14 |
Master is back in and everything bled with a bunch of clutch pumps. Took it for a littel test drive to make sure everything works. Its all in great functioning perfectly. Thanks again to Jim at www.powertorquesystems.com !!!!
Snow is coming, so back to winter for a day. Should have some sun and 70's soon enough.
03-22-2014 | #15 |
Anybody have any tips and tricks to ensure the shaft from
the slave centers on the socket of the clutch fork? You can't see it, and have to work by feel, which didn't work... And while we're at it, what genius put the bleed port on the bottom of the new slave? Had to back fill via the bleed valve to get the air out, flushed over a pint thru a system that probably holds only a few ounces. |
03-22-2014 | #16 |
Took C16 out for a drive today!
Think we sould change clutch and brake fluid in the 96???????? |
03-22-2014 | #17 | |
Getting the Air Out of the Clutch Hydraulics
Now.......fill (2/3 full) Master Cylinder reservoir with DOT 3 or DOT 4. As someone pumps clutch, open bleeder on Slave Cylinder each pump untill you get fluid. Close Bleeder. Continue to pump clutch holding 5 sec each time and release for 5 seconds. You will see some bubbles each release in Master Cylinder Reservoir. Continue untill you have Clutch release (keep Clutch Master Cylinder Reservoir 2/3 full at all times). Fill Master Cylinder Reservoir 3/4 full as Clutch Slave will continue to self bleed as you drive.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 03-23-2014 at 12:02 AM. |
03-22-2014 | #18 |
I've been using Ranger's method of changing clutch fluid for the last several years. Makes it easy and works without needing to get under the car.
Watch this video http://youtu.be/gBbsy0LjUvE
10-31-2018 | #19 |
I have seen on www.zfdoc.com that one the main reasons of transmission failure is because of a bad slave cylinder bleeding.
I changed my slave cylinder 2 years ago (about 1,000 miles driven since then). I tried to use the traditional 2-men method on the slave but it didn't seem to be very effective... I've got 3 other sports cars and lots of other things to do at the same time, can I just use the gravity method? Gravity method: I pump the clutch pedal 100 times, release pedal, open clutch bleeder, wait for (how long?), close bleeder, re-fill reservoir (make sure it stayed over LOW position) and I should be good to go? I only wait to release the air, not to replace to old fluid. To replace old fluid, I would guess the 2-men method would be good, before gravity bleeding it? What do you guys think?
Mazda RX-7 1992 Chevrolet Corvette ZR-1 1991 Dodge Viper RT/10 1994 Mercedes-Benz C63 AMG 2009 |
10-31-2018 | #20 | |
I realize you said you don't want to change the fluid, but, why the heck NOT(?) - might as well 'while you're down there anyway, right? Two years is plenty of time for contaminates (water, mostly) to need purging. Might as well 'kill two birds w/ one stone' (so to speak). Lemme just say this, far as purging the air goes: I'm NOT a big fan of pumping the clutch pedal 'a gazillion times' to try to get the air out. The trick is not to have air in the slave in the first place: any number of ways to accomplish that (e.g., pre-bleeding, etc.) Initially, pumping the clutch pedal method only gets the big air pockets out. But, the rest of the air? Continued pumping of the pedal tends to turn any air residing in the (slave) into an emulsion; a cloudy mix of hydraulic fluid and tiny bubbles (if you could see inside the slave). It will eventually work the emulsion out, IF you have the time before your knee gives out! Here's what can happen: Every time the clutch pedal is released, some of that emulsion is forced into the hydraulic line going to the MASTER cylinder and very limited amount (of the emulsion) actually escapes into the clutch reservoir. Then when the pedal is pressed again, fresh fluid has to push that emulsion trapped in the hydraulic line back into the slave. And, by the time fresh fluid arrives, it is at the end of the pedal stroke - very limited amount of fresh, clean fluid enters the slave. As a result, whatever fresh fluid does reach the slave, it serves only to dilute the emulsion that exists there. With each repeated pedal stroke, the emulsion is further diluted, but never completely purged: whatever air emulsion that remains will result in makinh the clutch "spongy" at a minimum, or (worse) fail to disengage the clutch completely - causing difficult shifts and damaging the gear teeth!
*Suggestion; I force the plunger rod against the car's frame (or something) while gripping the body of the slave cylinder with one hand, and holding an open end wrench to operate the bleeder valve with the other hand. (Here's where a SPEED BLEEDER installed on the 91+ slave cylinder would come in very handy! And, too...attaching a separate bleeder kit reservoir to keep the MASTER reservoir from running out of fluid is a special tool I can highly recommend!)(see attached) It should shift smoothly into any gear. Failure to shift into any ONE gear, may be an indication of synchro wear for that gear. But, difficulty or "notchy" shifting into any gear is one symptom of either air in the hydraulics, OR another problem stemming from worn or damaged seals in either the MASTER or SLAVE cylinders.
Tags |
clutch reservoir leaking |
