03-14-2014 | #41 |
Re: Tires
19x11.5 w/44mm offset
Clint & Sherry 1994 ZR-1 White/Red #152 (sold) 1991 ZR-1 Callaway Aerobody #1332 (sold) 1990 ZR-1 Red/Red #952 (sold) 2002 Z06 Torch Red/Mod Red widebody |
03-14-2014 | #42 |
Re: Tires
Thanks Hog. Funny thing is it seems that the nt-05 has an overall width of 12.4 and the goodyear gsd3 has a sectional width of 12.3. If I'm not mistaken that's two different ways of saying the same thing. I'm surprised the nittos are a hair wider.
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 |
03-16-2014 | #43 | |
Re: Tires
RIM WIDTH (IN)/ SECTION WIDTH (IN) /TREAD WIDTH (IN) /DIAMETER (IN) /WEIGHT (LBS) 335/35-17 MICHELIN PS2 11-13 /13.4/ 12.5 /26 /34 PRIELLI P-ZERO 11-13/ 13.8/ 13.3/ 26.1 /36 315/35-17 SUMITOMO-HRZ 10-12/ 12.6/ 11.5/ 25.7/ 28 GOODYEAR EAGLE F1 10.5-12.5/ 12.3 /11.2/ 25.7/ 30 KHUMO ECSTA XS 10.5-12.5/ 12.6/ 11.5/ 25.7/ 34 NITTO NT05 11-13/ 12.4/ 11.4*/25.6 / 30.5* Looks like Sumis are the lightest, Pirelli and Michelin 335s the widest, Nittos may have the narrowest tread width but I am not sure whether any of these statistics mean much. Surprised at the significant differences in weights. *Thanks to 1990 quasar blue for the tread width and weight on the Nittos--Bob
2016 Long Beach Red Z06 #10281 "POPS Z" 1995 Polo Green #409 "WARP TEN"--Haibeck 350/510 package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts --Sold but still running strong 1993 Quasar Blue #161 "HIL KING" --Sold but still running strong, now with more than 120,000 miles 1967 Marlboro Maroon/Saddle Corvette Coupe 300 hp/4-spd --Sold a long time ago ZR-1 Net Registry Founding Member #95 NCM Lifetime Member Favorite Quote--Attributed to Mickey Thompson: "Too Much Horsepower is Almost Enough" Last edited by WARP TEN; 03-22-2014 at 03:13 PM. |
03-16-2014 | #44 |
Re: Tires
I couldn't find that info either. The best I can do is weigh one tomorrow. Also if you tell me exactly how to measure the tread width I'll do that too.
03-16-2014 | #45 | |
Re: Tires
Tread Width The tread width is the distance between the outer edge and the inner edge of the tread of a new tire. However today's radial tires often feature tread designs that incorporate rounded shoulders and there is no industry standard pertaining to "how much" of the rounded shoulders should be included in the tread width measurement. Because of this, it is difficult to accurately compare the tread width differences of one tire brand to another. Tread width measurements are best used when comparing the various tire sizes or lines manufactured by a single tire manufacturer. Several tire manufacturers have chosen not to publish tread width dimensions. Good luck! --Bob
03-16-2014 | #46 |
Re: Tires
Bob the tread on these definitely wrap around. I actually used a piece of wire because an actual tape measure doesn't bend as tightly. When I measure that wire I get exactly 11 3/4". I'm not sure that's the best way to measure it. Any suggestions?
(Edit) 11-3/8" if I take the "wrap" portion of the tread out of the equation.
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 Last edited by 1990 quasar blue; 03-16-2014 at 08:25 PM. |
03-17-2014 | #47 | |
Re: Tires
03-17-2014 | #48 |
Re: Tires
"Overall width" is a term I havent personally heard, but I would agree with you that Overall and Section width are describing the same measurement.
peace Paul ZR-1 Net Registry Member #1494 |
03-17-2014 | #49 | |
Re: Tires
Wow, look at the differnce in the 335mm tires. Both are a 335/35-17, the Michelin has a 12.5" tread width and the Pirelli has a 13.3" tread width. Going with the Pirelli gives you an extra 1.6" of tread width total on the rear end, quite substantial. Of course assuming that both tread widths exactky comparable. Cool.
03-17-2014 | #50 | |
Re: Tires
