Old 03-07-2014   #31
Schrade
Default Re: Delco Bose AUX Input soldered connection...
I did not Jeff; only 2 items I have are posted here, and as Scott pointed out, one was only for a Bose later model that has balance control...
Are you working on a power defeat for the CD, with AUX plugged in? Post up if you accomplish it...
No luck Jeff - only 1 left of the 2 that I got from Bob at carstereohelp.com
he has 2 numbers 800 428 1909 407 830 0777
Both schematics that I got from him are here http://www.zr1.net/forum/showpost.ph...8&postcount=32
sorry I can't help more there..........
Old 03-09-2014   #32
scottfab
scottfab's Avatar
According to what I see pin 1 is shorted to pin 4 ?
Pin 4 is "Right channel In" and pin 1 is "Ground".
I'm a bit confused.
...snip...
3.5MM jack soldered to shielded cable:
excess on terminal #1 snipped; no 2-4 bridge!!!
jack pinout ID:
Scott
Old 03-09-2014   #33
Schrade
I should have said "no 1 - 4 bridge".
excess on terminal #1 snipped; no 2-4 bridge!!!.
Old 03-09-2014   #34
scottfab
scottfab's Avatar
OH ok.... then it looks like this then with a ground going to pin 1 only.
And the ground is the audio ground and not the car ground.
Scott
