Old 03-05-2014   #11
Default Re: Shift knob
Clint,
This is a C5 knob I had re-done by Redline. Button is the same. I had the wrong button inserted at the time of the pic.
A view of some additional interior pieces.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 03-05-2014   #12
Go to www.redlinegoods.com. They have an example of a red/black knob they did using a C5 knob. They show mine as well.
Old 03-05-2014   #13
WVZR-1
Originally Posted by USAZR1 View Post
Will a C4 shift pattern insert fit in a C5 shift knob? Anyone know where I can find a C4 shift knob in Torch Red? My upholstery shop can reupholster ours but I would rather just buy one,outright.
I would think there are many used knobs available for use as a core for the one you would like done. I might have one but it might take an effort to put a "hands on"! It might be to your advantage to have a core done by "your guy" vs. an outright buy. If your guy says he can "match" the color you're good. An after-market buy might likely be hit or miss.
Will the insert fit a C5 knob I don't know - is the height of the C5 knob comparable to the C4? I don't know that either but I'd make sure before I did a buy. It doesn't take much difference in height to feel the difference. Shorter might be good. The other thing I guess to check would be the lift-ring functionality. I'm assuming your car has the stock shifter. If it doesn't then maybe it's not an issue.
Old 03-05-2014   #14
USAZR1
USAZR1's Avatar
Thanks for the link,Dom. If my upholstery shop will not re-cover mine,I'll get what I need from Redline.
Clint & Sherry
1994 ZR-1 White/Red #152 (sold)
1991 ZR-1 Callaway Aerobody #1332 (sold)
1990 ZR-1 Red/Red #952 (sold)
2002 Z06 Torch Red/Mod Red widebody
USAZR1 is offline   Reply With Quote
Old 03-05-2014   #15
USAZR1
USAZR1's Avatar
All good points,Dave. If I do decide to go with Redline,I'll definitely call them first and make sure I can get the cover in Torch Red.
Yes,our ZR-1 still has the stock shifter.
Clint & Sherry
Old 03-05-2014   #16
Default Re: Shift knobs
Clint,
Here's pics of a C5 knob re-done by Redline v stock C4 knob. Should answer your questions. The Redline re-cover adds some added heft to the knob, which I like. The C4 knob is black, obviously.
Shift button obviously fits. Like I said. They're identical.
Old 03-05-2014   #17
WVZR-1
Clint,
So it makes the "core" shopping easy - if you like the stitching pattern of the C5 then you use the C5 core so the trimmer can match the stitching or if you prefer the C4 stitching you provide the trimmer with a C4 core. Easy enough.
Old 03-09-2014   #18
USAZR1
USAZR1's Avatar
Do the aftermarket shifters (Hurst,B&M,etc) use the same 9/16-18 thread as the stock shifter?
Clint & Sherry
Old 03-09-2014   #19
WVZR-1
Yes they do and that was the reason for my earlier comment as to that was the only similarity! Of course there's no locking device so it's accomplished with a jam nut. Now if you leave the jam nut off the lever will seat much deeper into the knob and effectively reduce the shift lever length.
This creates a separate issue in that the shift pattern if it's a "patterned knob" is likely not indexed properly. This can be accomplished by stacking washers on the shift lever to effectively change the index of the knob. Mine when secured with no washers is indexed perfectly.
Don't use the jam nut unless you actually want to use it to lock it more securely. Mine is secure with no additional help needed. Lift ring works perfectly - no interference.
Old 03-09-2014   #20
The Hurst shifter uses the exact same thread and locking mechanism as the stock shifter. Not familiar w B&M.
