Old 12-04-2013   #51
Default Re: ROZA NERO Interior Conversion
Here's an update. Took advantage of the 50F day before we head into deep freeze.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 12-04-2013   #52
Wow
Great job Dom!!!
Old 12-05-2013   #53
cvette98pacecar
Took advantage of some nice weather here today. I was able to remove the console frame, passenger seat and remainder of the carpeting. Loads of wires.
The 92 was the first year w ASR, so what would normally be a second rear hatch bin is full of hydraulics and electronics. The "door" to the bin is bolted shut and so the hatch carpet only has one flap and one hatch pull handle w lock. Well the 90 carpet is setup for 2 bin doors, pull handles and locks. Got a bin door from a 91 along w a lock to fill the hole. Now I should be able to install the pull handle onto the hatch carpet.
A few shots of the car devoid of carpeting and seats and just starting to install riser and hatch side carpeting.
Dom, you are giving me flash backs from when I had the entire interior out of the Aerobody.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
[COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member
NCM Lifetime Member #2655
Pacecar Registry Member
[COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR]
[COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR]
[COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR]
1991 Callaway Aerobody ZR-1, DRM 500
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 12-05-2013   #54
Blue Flame Restorations
Good job, Dom.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 12-05-2013   #55
Couple of side notes.
1. In the course of removing the black interior I cut the wire for my GPS sensor. Thought I could splice it but then I noticed there is an outer shielding with and inner insulated wire. Need to check on whether it can be spliced.
2. The 92 was the first year of ASR. Consequently the bin hatch behind the driver is bolted closed, while previous years there were 2 pull handles and locks.
The 92 only has one. I replaced the driver's side bin door with one from a 91 and will install a second lock. Then I can install the bin door pull for the bin on the driver's side. The carpeting for the hatch area already was cut for this otherwise it would have looked unfinished.
3. The halo trim will be painted cognac to match the rest of the interior. Was thinking of doing same for package tray trim in rear hatch area. My wife says she likes the contrast of the Cognac w the black however.
Old 12-05-2013   #56
Schrade
Lookin' real good there...
If the wife offers preferences, TAKE HEED. Happy wives are HARD to come by ...
Is the GPS wire co-ax? Or tri-axial? If co-axial, you can get compression fittings and a barrel connector, along with 'the tool', at the local DIY. Or catch the local telecom field tech in your neighborhood. Might offer to ante up his lunch...
Old 12-05-2013   #57
Chuck,
Looks like a co-axial. Looks like about a 14ga wire.
Old 12-22-2013   #58
Pretty much have front part done. Cluster and console are together. Also, took a slight detour Nd installed one of Marc's steering column pins to tighten things up which it did. Finishing up the hatch area is next. depends on weather. After the interior I'll be tackling the rear Z06 brake install. I'll put that in a different thread.
Old 12-23-2013   #59
You can paint carpet....midamerican sells the paint if you are interested in covering up the red stain under the seat
Old 12-29-2013   #60
Took advantage of the "mild" weather we've had over the last few days. 50F yesterday in Chicago. 30's today before the deep freeze comes back. I must have taken the console apart and put back together about 5 times because of getting the assembly sequence wrong. What a PITA. I don't recall my 84 being this much hassle when I replaced carpet and seats in it.
The steering column fix set me back a bit too. Accessing the knee bolster reinforcement bolts up tight against the console make pulling the console side carpeting a "must". Otherwise you'll spend more time trying to get at it, than doing the rest of the job. Then "chasing" the starts/dies thing had me dropping the column ONE MORE TIME! Marc's oversize pin really did help in tightening up the column slop.
Now I can actually lean on it and it doesn't budge. So the front end is together with the exception of seats(getting seat covers made) and seat belt buckle.
Hope to finish rear hatch today. Radio bezels and targa storage bezels are on.
Need to check on painting of halo trim. I am also going to have the seat back shells painted to match OR should I leave them contrasting?
Speaking of seat covers, I spent time removing the D/S cover so the upholsterer has a pattern for the new covers. Aside from the typical left bolster wear, the cover is in very good condition. I may sell it if I get it back in original condition.
I will be taking the passenger side off as well. That seat cover is in pretty much pristine condition. I'll be putting it up for sale shortly, FYI.
