Old 12-03-2013   #21
Tyler Townsley
Default Re: Installed No Flex Frame Stiffener Bar System
I really think these should have been a part of the ZR-1 package. The motor has so much HP that hammering the throttle twists the frame and causes the positraction to react further amplifying the problem. I believe this sets in motion a back and forth momentum in the chassis that prevents low speed hookup. Once the car finally dampens this motion it then can really start to roll. JMHO,
Tyler
55 Polo White (Project)
61 Jewel Blue (Sold to buy above)
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 12-03-2013   #22
efnfast
Tyler
Yup, just experianced that. In first gear, it was hop hop hop, chirp chirp chirp. Think these would help that?
Old 12-03-2013   #23
Old hard rubber tires .......hop hop hop, chirp chirp chirp
Maybe time for some new rubber
Discount Tire
FRONT.................................................. ....................REAR
Nitto NT 555 Extreme Performance..................................Nitto NT 555R Drag Radial
P275/40ZR-17 98W.................................................. ...315/35R-17 102V B
Old 12-03-2013   #24
efnfast
Fairly new rubber, two years old, but new found power. Ported plenum and IH.
Old 12-03-2013   #25
Tyler Townsley
Yes.
Tyler
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 12-03-2013   #26
Yes.
Tyler
Tyler,
So you think these would help the ZR "bite" better at the track? And w more power, getting it to the ground gets more problematic. Is that why the ZR appears to accelerate stronger in the second half of the 1/4?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 12-06-2013   #27
Tyler Townsley
Tyler,
Just using 60 ft times you can see there is something going on, the only car I know of that solved that was Fastlane and he went with a Ford 9 inch which would resist the torqueing better. The only other solution would be a computer controlled traction control and even then I think the flex would still be a problem.
Tyler
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
Old 12-08-2013   #28
aafc
aafc's Avatar
Jeff,
With your black ZR-1 the mounting bolts show up. You could just paint them
black ,or install 49th street rockers to hide the front and rear mounting bolts.
I drag race my Zr-1 and my 60ft. times avg. 1.73 to 1.78 , 1/4 mile times
avg 11.65 to 11.72 @ 118- 120 mph. I might have to look into frame stiffener
bar system.
John Becker
1990 white/black # 2546
one of a few auto (4l80E ) eq. ZR-1's
Old 12-08-2013   #29
Yeah, I have the rockers waiting to get painted
Old 12-26-2013   #30
aafc
aafc's Avatar
I ordered the no flex frame stiffener for my 1990 auto eq. zr-1 on Dec.
17. 2013. installation was completed on the 21 of Dec on a 4 post lift.It took
a little longer then what the instructions said. Front brackets took about
20 mins to install. The rear brackets took a bit longer because i have DRM
c4 trailing arm brackets installed. the lower dog leg had to be moved to gain
access to the lower trailing arm bracket bolt.
After installing the rear frame stiffener bracket and bolt, torque the assembly
to 80 lbs. The lower dog leg was reinstalled and ride height checked.
Without adjusting the frame stiffener i jacked up the car at the right front
(about 5in off the ground) i could not open the doors. lowered the car tighten
the frame stiffener bars and raised the right front again, i could open the door.
Took the z for a ride Sunday the 22nd, car felt more stable without body
flex.
I drag race my z and have pulled 60ft times of 1.73 to 1.79 running 11.69
to 11.76 @ 117-119 mph. Next test and tune will be Jan 4, 2014, I'll
you know how this works out.
Merry Christmas
John Becker
member #0115
