Old 10-04-2013   #1
Default ROZA NERO Interior Conversion
Well I have been asked to document conversion of my interior from black to Cognac. The car is a 92 Black Rose w black interior. 2 of my Vettes, the 72 and 84, both had saddle interiors. I thought black rose would benefit and brighten from installing a similar interior. I thought more of the red would come through w the cognac interior. Looking for a classic color combo. Still need seats or covers and rear carpet, but I thought I'd start installing the "easier" pieces to start getting an idea of how it would actually look. So I have finished drivers side door panel, hush panel, and sill.
Here's a couple of shots:
Compared to this:
As =Jeff= would tell you, on any conversion there's always something. As much as things look like they haven't changed, we find small things that make the conversion process a PITA. Tolerances from year to year change. Having worked in at a GM assembly plant for 6 years, I can tell you "substitutions" happen all the time.
Here's an example of the difference between 91 and 92 interior bits that wasn't very obvious until you start swapping parts. Door and interior night lights.
Old 10-04-2013   #2
Default Re: ROZA NERO Interior Conversion
Dom are you going to carry the Black inner door theme to the other door by removing the black arm rest and door pull on the passenger side? The original passenger door never carried the dash color beyond the passenger side of the dash however, I think it look so much better if the left side and right match doors. I noticed this in Phils car when we were working on the hatch as his is Red on Cognac. He said he thought that was the way GM wanted it to keep the "Cockpit" feel.
Im replacing my passenger door panel in a month (When its cooler) I offered to give my black insides to Phil however Im not sure if he wants them.
The 90-93 Doors were a lot better structurally and had removable parts. The 94-96 doors were cheap one pieces POS panels with the hidden doors in the arm rests as the only redeaming feature.
Old 10-08-2013   #3
Dom ????
Old 10-08-2013   #4
I am watching closely
Old 10-08-2013   #5
Dom ????
Guys,
Well I spent the weekend doing both doors and sills. I'll take pics. I thought about your suggestion regarding the swapping black armrests, but I would agree w Phil regarding the "cockpit" feel for the drivers side. I am sure it would look good w the black but I am trying to get away from that. Besides, the pass. door panel is in very good shape and OEM. I really don't want to hack it and be left w a worthless panel. Need to do the pass side knee bolster but before I start ripping out the seats, need to land on a rear carpet set that includes the riser. I have the front footwells, sills, doors,and B pillar. Willcox has a 20% discount on carpet sets.
The door panels are a bit of a PITA to line up the screw holes, especially the ones in the armrest recess. Lots of put on/take off to make sure the mounting sequence works w wndow switch, door switch etc.
Needed to drill different holes for the door sill covers.
After the carpet, the issue will be seats or seat covers. In the meantime,
black seats won't look bad.
Old 10-08-2013   #6
If I remember right Dom those pieces of the panel etc just unscrew so the transfer would be easy.
Old 10-08-2013   #7
Scrrem
Scrrem's Avatar
Looks great Domnic!! Can't wait to see it finished.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 10-08-2013   #8
Yes I saw that. Got a bit impatient to get this part done.
Thanks Rich. I think it will be a classic look and the cognac brings out more of the ROSE in the body.
Old 10-08-2013   #9
Scrrem
Scrrem's Avatar
I still have my rear carpet if you need any pieces
Rich
Ron Davis Radiator
Old 10-08-2013   #10
Some additional pics. Light is a bit poor.
A quick compare before
After
