Old 09-19-2013   #1
alwayscode390
Question My car looks lowered, how do I tell how? ---
My car looks SLAMMED in the front, and a little lower in the rear than some of the stock ZR-1's I have seen in pics.
When I look at the suspension, I don't see anything screaming at me that its a "newer" part, or not OEM.
How are these cars usually lowered?
Point me where to look to see how they did this.
Thanks! ---
MINE:
STOCK:
Its not a TON of difference now that I look , but I do see 1-2" front and rear. Could that be caused by worn shocks? LOL ---
[SIGPIC][/SIGPIC]
01' Dodge Viper GTS
11' Ford Raptor
90' ZR-1 Corvette LPE #699
Old 09-19-2013   #2
WVZR-1
Default Re: My car looks lowered, how do I tell how? ---
The front spring is removed and the top portion of the cushion is trimmed away to near nothing and then a "strip" of a desired thickness is "glued" to it. Here's a spring cut before adding the "strip"!
This kit might have been used:
OR it could have had an after-market spring added to the front to accomplish the lowering. Reversing it would likely be more easily done by purchasing a "take-out" from someone that did coil overs. You could compare to yours and then modify the thickness perhaps between the height of "stock" pad to what you have presently to get the height you might want.
Looks just about right now!
Old 09-19-2013   #3
What size tires and wheels you running?
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 09-19-2013   #4
alwayscode390
275/40/17 fronts and 335/35/17 rears.
Here is what my front tire looks like turned :
Are coil-overs the only option for the rear? Im not really familiar with the independent rear suspensions quite yet.
Thanks WVZR-1 ---
[SIGPIC][/SIGPIC]
01' Dodge Viper GTS
11' Ford Raptor
Old 09-19-2013   #5
looks lowered to me too
Old 09-20-2013   #6
WVZR-1
Thanks WVZR-1 ---
You can change the "stack" of the shims that mount the spring to the rear axle cover. I don't recall the "stack" in the ZR-1 but there's 6.1mm, 5.2mm, 4.3mm and 1.72 available. They're done in combinations on some applications. Maybe yours has already been done that way. A couple/few less mm on the top of the spring could effect it maybe more than one thinks. Measure what is there.
On the spring bolts at each end of your spring are there castellated nuts that are cotter keyed? If they're cotter keyed and 192mm long they're original to the '90, if they're 225mm they're later ones and if there's no cotter keyed nuts then they're after-market. Changing the stack and using the longer later bolts with cotter keyed nuts would maintain the "stock" appearance or just use still longer bolts but use castellated nuts and cotter keys.
Old 09-20-2013   #7
Bob Eyres
Sometimes pix are deceptive, but your car doesn't look lowered to me. Certainly the front is no lower than my 91', and it's stock.
BTW, nice wheels
"It's about the car, not the people."
1991 ZR-1 White/Black #1236 (Owner since 1994).
Stock engine with bolt-ons: Hurst shifter,"Forced Air" intake, Coplon duct, Bee Cool Radiator, Demon coils, Jeal prom, Watson headers, X pipe, 3" B&B's, Rippie flywheel, 4:10 gears, A molds, Toyo Proxes-R888's 12.06@117mph. 1.76 60ft.
Old 09-20-2013   #8
icarus-54
icarus-54's Avatar
Matt,
looks the same as mine
1990 Zr-1 #361
1991 GMC Syclone (built)
1993 GMC Typhoon (stock)
1993 GMC Typhoon (street)
1992 GMC Sonoma GT
1928 Model A pick up
icarus-54 is offline   Reply With Quote
Old 09-20-2013   #9
Schrade
Doesn't FSM have specs for this?
Duh. FSM has everything. Except number for Domino's (but my '94 FSM had GORDON KILLIBREW'S # inside the back cover )
sorry about snappic quality here; new scanner / printer / copier / SD/MMC card reader / has me licked so far - thing does everything except windows, I think (actually is easier to navigate in Windows too, than Linux ). I swear Microsoft is in cahoots with other hardware manufacturers, even after they got busted with FoxConn
Old 09-20-2013   #10
alwayscode390
Thank you Schrade!
So I am looking for a measurement of "J" from the bottom of the door hinge to the ground?
Sorry but I don't understand the model number (07 or 67), or what suspension I am looking for (1 or 7) .
This is the reason I think mine is lowered, I have seen MANY pics of stock 90z's that look like this:
[SIGPIC][/SIGPIC]
01' Dodge Viper GTS
11' Ford Raptor
