Old 07-09-2013   #1
GTOger
Default Recommendation for cats
I still have 2 years before I can run "classic" plates here in Texas, so in the meantime, I'm subject to emissions testing. The car has failed with high Nox and HC. The kicker is I got a letter from the state that tells me they won't issue new tags because the car has not passed emissions. How it makes any sense at all that our Governor will issue exemptions for coal-fired power plants, but my 39k mile Corvette is apparently at fault for killing the environment is beyond me but that's another rant for another day.
What I really want to ask is: What recommendations are out there for replacement cats for a 1990 ZR-1?
[B]1990 Corvette ZR-1 (#1930)
Red/Black, Stock Engine, Henderson Performance custom ECM, FIC Injectors, B&B exhaust, Kenwood DNX6160[/B]
Other Rides:
1992 Pontiac Firehawk (#010), 1967 Pontiac GTO
1998 Porsche 968, 2000 Harley Davidson FXST
1986 Pontiac Trans Am, 1931 Ford Model A Tudor Deluxe
GTOger is offline   Reply With Quote
Old 07-09-2013   #2
Default Re: Recommendation for cats
The problem for the 90~92, is that the cats are welded to the exhaust manifolds, like a collector section, so they will have to stay on the manifold. New cats can be added downstream but first, the old cats should be cleaned out/gutted completely, which requires removing the manifolds. Here's a photo to see how it is made.
The foregoing is the least expensive. The other solutions would include buying another set of used manifolds with good cats, 90~92 or 93~95 which are listed in the parts manual as direct replacements. The other option is to toss the stock manifolds and install long tube headers & flange/clamp in cats behind them.
if you go with aftermarket cats, use only those with metallic substrate.
Old 07-09-2013   #3
i've had good luck with russian blues and orange tabbies...
wait wrong cats
Old 07-09-2013   #4
Fully Vetted
Fully Vetted's Avatar
When I bought my car last year I couldn't even get the title transferred until it would pass. It came from a non-sniff state so it needed some work. It already had SW long tubes on it and no cats. So, I took it to Corey and he retuned it and I gave him the cheapest bullet cats I could find at Summit Racing and he installed them using the good flange connectors. I replaced the oxygen sensors and it passed. I don't know by how much it passed but it passed. Then I promptly removed the cats...
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 07-09-2013   #5
My advise if you need to get another 2 years try to find a set of used replacements. Trust me this is a PITA and a lot of work however for my 91 I went with a set of long tubes and randam tech hi flow cats. The car still will not pass the treadmill test. It might on a sniffer test only and I dont know what your emissions tests are like in Texas.
Old 07-09-2013   #6
Fully Vetted
Good recommendation. Random Tech are the best you can buy. They're a little pricey but no doubt the best. If I was going to leave them on I would have gone with them but I only needed "testers" so I went cheap.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 07-09-2013   #7
GTOger
There is something to be said for the removable method. You know, so you can pull the cats off for off-road use. It may be time to do the header thing. The manifolds have to come off the car either way, so.... yeah, it may be time.
Other Rides:
Old 07-09-2013   #8
USAFPILOT
USAFPILOT's Avatar
The cheap bullet cats that came with my SW headers are causing me a headache. I can just barely pass by running 1/3 tank of 93 Oct and a quart of denatured alcohol from Home Depot. The Nox will come down when you put in the alcohol but the HC's will increase. It is all about the blend.
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI.
Old 07-09-2013   #9
GTOger
Thanks for that, Pilot. I'd ideally like to have cats that can bolt-in/out. I wonder if there are any recommendations?
Other Rides:
Old 07-09-2013   #10
Jagdpanzer
Jagdpanzer's Avatar
Here are the temporary cats I rigged up to get through Virginia emission test.
Link to full details http://www.zr1.net/forum/showpost.ph...57&postcount=5
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
