Old 07-04-2013   #1
RiceEatingZR1
RiceEatingZR1's Avatar
Default what is considered high milage for a ZR-1?
Or does it really matter since the the newest car is 18 years old?
-Shaun
1991 Charcoal Metallic ZR1 #730
[URL="http://www.cardomain.com/ride/2649606"]http://www.cardomain.com/ride/2649606[/URL]
[URL="http://community.webshots.com/user/shaun91zr1"][/URL]
[IMG]http://img.photobucket.com/albums/v211/RiceEatingZR1/Forum%20Sig/Sig1.gif[/IMG]
RiceEatingZR1 is offline   Reply With Quote
Old 07-04-2013   #2
Blue Flame Restorations
Default Re: what is considered high milage for a ZR-1?
Seems that most people say when it its 100k, it's a high miler. As long as it's maintained properly, it should go another 100k with no bottom end issues.
Just my opinion. You'll get a lot of them...
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 07-04-2013   #3
These sucker's go on forever if maintained well. I have seen ZR1's with 150K plus that ran and looked like a 15K miler. In fact the car ran like a scalded dog.
Just a thought.....one never hear's the question on how many mile's are on that 63-67 Corvette's. I really don't think it matter's , again providing the car has been taken care of.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 07-04-2013   #4
My chassis has 120k +, but the drivetrain and suspension have been re-done, the motor has about 35k on it. So is it newer, or is it a 120k mile car?
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 07-05-2013   #5
It all depends on how it is maintained exactly as Frank (aka FU) suggested, how hard it is driven, and over what terrain it is driven........and it depends a bit on the lubricants you use and it also depends on WHO re-done and WHO maintains
It is assumed inside storage and with no mice
Knowing you Know Stuff.......... yours (XfireZ51) is probably a 35K car if the suspension was redone when you re-did the motor.
Old 07-05-2013   #6
Dyno,
Mine was pretty much a rhetorical question. From a collector POV, car is 120k.
For me it runs like a much newer vehicle. The nice thing is that you can continue refreshing it so in the end as others have pointed out, mileage really matters little.
Old 07-05-2013   #7
Dyno,
Rhetorical question or not......it appears you have now put on 32.5K miles on these cams since these photos?
So I have pulled the cam cover and I have a few pics that I am posting for Pete because I thought it would be interesting to see the condition of the cam lobes after 2500miles.
Old 07-05-2013   #8
mike100
For a GM car, I'd say 200k miles is about where the typical chassis is just plain worn. The wire harness has suffered wear and tear from many repairs and heat cycles, the suspension and chassis stiffness is affected.
A friend of mine insisted on driving his 89 IROC z-28 into the ground. 300k miles and the doors dropped an inch lower when you opened them from loose hinges. on the 2nd and a half engine job, rear axle done over...pretty much everything had been touched...at some point you are throwing good money after bad. Of course the ZR-1 has value and should have the justification for more service costs, but there has to be a point when a car will start looking real good as a spare parts car when you can just find another tighter 60k mile one for a decent price.
Old 07-05-2013   #9
No I don't. The intake cams were installed when I first got the car and that's about 10k miles. The exhaust cams have recently been installed and now have 2k miles on them. The motor was originally swapped from #474 nearly 3 years ago. That motor was a service replacement from the original motor when 474 had 16k miles on odo and I bought the car w 35k miles. So new motor had 19k on it when I bought the car. When we swapped motor, 474 had ~52k miles on it so motor now had 36k on it. And I've put 10k on 458 w Pete's intake cams. I think he may have taken pics of cams when he installed exhaust cams this year.
When we looked at the motor during the install, the intake cams still looked like the pic you have above. No wear indication so I feel pretty comfortable w using the Castrol GTX Diesel 15W-40 that I have been using for the last several years.
Old 07-05-2013   #10
Blownrunner
I saw a tv clip where editor from hot rod tv stated he had 300k on his daily driver zr-1..
Blownrunner is offline   Reply With Quote
