Old 06-02-2013   #1
JimZRyd
JimZRyd's Avatar
Default I'm missing an elbow....
Looking for some help from you guys. A forum Z owner pointed out to me yesterday that a little rubber elbow was missing under my hood. This piece is located just behind the plenium at the top towards the windshield. Im not sure what its called since I'm new to the LT5 and I as yet do not have a repair manual. What is it and where can I get a replacement? Thanks in advance!
Jim Zorgias
1994 ZR-1 Admiral Blue/Black #245
1996 Callaway Supernatural 450
1990 Callaway Supernatural 490 / CR-1 #7
JimZRyd is offline   Reply With Quote
Old 06-02-2013   #2
Default Re: I'm missing an elbow....
any autozone or parts store has them: thats the fuel pressure regulator
Old 06-02-2013   #3
http://www.autozone.com/autozone/acc...questid=365836
Old 06-02-2013   #4
JimZRyd
JimZRyd's Avatar
Thanks! I'll swing by one tomorrow.
Jim Zorgias
Old 06-03-2013   #5
Funracer
Thumbs up Re: I'm missing an elbow....
Lee is correct. I bought one a couple of weeks ago and it fits perfect.
Bring the half you do have with you to be sure the ends fit together.
When you get the right elbow, a small zip tie on both ends should keep it all
together.
Welcome to the club!
Funracer is offline   Reply With Quote
Old 06-03-2013   #6
JimZRyd
JimZRyd's Avatar
Thanks again! Yes Lee was right on the ball! Picked up a set this afternoon and found the right one with no problem. The larger inlet side took a little effort to get it over the inlet but it worked out. Thanks!
Jim Zorgias
Old 06-03-2013   #7
Fully Vetted
Fully Vetted's Avatar
The Brotherhood at work....
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 06-03-2013   #8
Schrade
Board members here ARE pretty much the FSM!
Anyway, long as you got 1 elbow left, makes it easier to get those morning trophys!!!
