Old 05-04-2013   #1
Racinfan83
Default Spark Plug Removal Question
Probably a dumb question but I'm gettin old...
I'm gonna change out the plugs next week - not sure if they have EVER been replaced. 17k miles on car. Can or should I shoot some penetrating oil down in there before I try to take them out? Would using a small drill driver impact be a good idea? I know to put anti seize on them before I put em back in - not sure if the ones in it now got it.... Anybody know the torque right off hand?
Old 05-04-2013   #2
efnfast
Default Re: Spark Plug Removal Question
This is from Marc H.
Hi Steve,
For high load operation I recommend a spark plug that is one AC heat range cooler than the OE plug. The best spark plug is the NGK TR7IX. Part number 3690.
It has a tapered seat. All LT5's are machined for both tapered and flat seat plugs. Carefully open the gap to .050"
Best of luck.
Marc
Somewhere is is recommended to over tourque the plugs if using a tappered seat for the first time and then backing off. I see if I can find that. -Steve
Old 05-04-2013   #3
vilant
Had 34K on my '90 and the original plugs came out easy enough. I wouldn't squirt any oil or other breaking type oils unless absolutly necessary. The torque is 19 ft/lbs. #8 plug is tricky, everyone tackles it a different way.
Joe
1990 Bright Red ZR-1 #2599
Old 05-04-2013   #4
Racinfan83
I got a Blackhawk swivel spark plug socket for that #8 one - read somewhere that one of those was the trick... I hope so..
I will try just removing them normally and see how it goes. I got the AC 41-602 for now - just since I want to change them out and see how bad the old ones are. Hoping to get car to Marc sometime this year for some other stuff - so I can always change them to something better at that time...
Old 05-05-2013   #5
I understand too that it is always a good idea to remove the plugs with the engine warm - the aluminum expands around the plugs which expand less rapidly - reducing the friction between the plug and the relatively soft aluminum. AND, as mentioned, you want to coat the threads of the new plugs with anti-sieze.
Far as the 41-602s go, those are the plugs Pete and I use. They're good enough for 10,000 miles, I suppose, but I've only put 14k miles on my Z in 5 years. So, I figger it is cheap enough to keep new plugs in her and she seems to run OK on 'em. So, I see using the 41-602s as an advantage over having to wring out the last few miles on a set of pricy plugs before spending big $$ for platinum/iridium gee wizz spark plugs for no apparent advantage (that I can see in my driving). (Your MMV).
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 05-05-2013   #6
I use the NGK BKR6E. It's one step colder than the stock plug or the 602s. We just took a set out from my motor and they looked pretty good as far as heat range. Check your ground strap. it needs to change color at the radius. if it doesn't its either too cold or too hot.
I take my plugs out when the motor is cold and do not use anti-seize any longer. I found that w anti-seize the plugs constantly needed re-torque.
Marc suggested a light coat of oil on the threads before install. That works well.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-05-2013   #7
scottfab
scottfab's Avatar
We all have our own take on what's best. After 16yrs of doing this here are my opinions.
...snip... Can or should I shoot some penetrating oil down in there before I try to take them out?
The way I see it, using penetrating oil will not be needed but can't hurt a thing if you use it.
I'd definitely NOT use it for several reasons.
The trick is not using too much. Then they stay tight and no re-tightening is needed. I smear only a single line of anti seize across the a 1/4in wide swath. I avoid trying to hit all threads all the way around. The idea is to reduce the likely hood of binding not eliminate it everywhere.
The FSM says 15lb for torque. I use 20lb because the anti seize effects the tightness. The FSM also recommends letting the heads cool down before removing the plugs but I agree with others. Hotter is better for removing. The exception is #8 or you'll burn your pinkies. Warm is better there
Scott
Old 05-05-2013   #8
Racinfan83
Good deal. I def appreciate the replies! Will see what I can get done next week on my days off. I got plugs, air filter, and pcv valves, and going to look at cleaning the radiator and fabbing a radiator debris screen. Stuff I can do - a bit at a time...
Old 05-05-2013   #9
efnfast
PCV valves, you might want to considerr the f tube that they are attached to. Jerry's Gaskets now has these.
Old 05-05-2013   #10
Schrade
Seems to me that if you spray in a little too much penetrating fluid, you stand a chance of excess draining into the cylinder after the plug is out. Draining along with a grain of sand or 2 or 6...
